Root [ROM] GingerSteem Extreme for LG Esteem MS910
Make sure your lcd density is set to 240 you can do this with a app called lcd density modder from the play store . Just set to 240. Reset the google playstore app .and reboot your device and all apps should be good to go
Are you on ZVB?
Hi..I did the same thing downloaded this ROM on ZVD. Is there a way to remove the ROM? I have some of the same issues like i've read on here..incompatible apps on Google Play, bluetooth, and Netflix app will open but just loops on "loading" movie.
Can someone tell me what I can do to correct these issues?
You ca do the samething just fix the lcd to 240 this rom was made with 210 or 220 i think . Change to 240 and it would work
