DTowns Finest
Member
Hey playful I looked around and maybe I'm overlooking but I can't get YouTube to work. It loads the home pages but when I click a video it just loads. I'm on this rom with phone candy 1.7 theme. Any help would be appreciated.
That happened to me before. If you're talking about the YouTube app I reinstalled and it worked again.
Sent from my LG-MS910 using Tapatalk 2 Beta-5
Yes that's what I'm referring to. Did you just reinstall the YouTube or the full rom. And if it was the full rom would I also have to reflash phone candy also.?
Nope just the YouTube app.
Sent from my LG-MS910 using Tapatalk 2 Beta-6
bingo!!!!How do download just YouTube if it's a system app or do you have to delete it through root explorer then redownload?
bingo!!!!![]()
any new rom that work properly with zvd and must i need to have the phone activated with metro in order to do put a new rom or i can make it just with the wifi service.
download to a cpu?Absolutly! You can download the links to a CPU to transfer to the EX SD and flash them that way. Your options are all container in here.
LG Esteem: All things Root Guide - Android Forums
Welcome to AF![]()
Files(zips)download to a cpu?
This one I am not sure if it will or not. GSE II will tho.does this rom work if its flashed and add the speed kernal ZVD?
kool is there a gingsteem extreme 3 for zvd?This one I am not sure if it will or not. GSE II will tho.
