the icon you see is location, that only goes away when you switch to e911 mode for location settings. and bluetooth issues have been on and off, im sure its just a simple mistake easily forgotten about..Not bad, could be better. I've been using this ROM for a few days and noticed some things not right. I turn GPS off and the icon is still on the home screen. The big disappointment, bluetooth doesn't work right anymore. I can't connect to anything via bluetooth.
nope I've never had zva files except when I first started working on CWM, which were all replaced during the process of getting it fully workingWas this ever based off zva? Seen in the op you say its based off zvb. Just wondering.
Is it just me, or does anyone else have the issue of downloading from the app store?
When I go to download things such as Dropbox or other apps that I previously had on my phone before the ROM, it tells me that the app is no compatible with my phone anymore?
Also the phone dialer screen is off as well ?
For market use ROM toolbox to change LCD density to 240.. then reboot..dialer don't know ..on stock as of now:thumbup:
You mean you are on stock? You mean you are on stock ROM?
I changed the LCD Display and it didn't help with the market, apps are still incompatible..
Yessir, that is what i changed. I rebooted after and i am having thesame market issue. The issue with the dialer seemed to have fixed itself.Out of the box stock B
You changed this:
After you set the LCD density to 240 and reboot make sure you clear the android market data before going into the market. Should fix it.
TRY REPLACING UR MARKET WITH THIS ONE IT WORKED FOR ME TRANSPARENT BLUE MARKET 3.4.4 INSTALL WITH CWM JUST WIPE CACHE AND DAVLIK CACHE THEN INSTALL THIS WILL REPLACE UR CURRENT MARKET
here u go
http://db.tt/j3E4SCZg
Idk if its just me or something i did but my MMS isn't working. The message just keeps trying to send and the person never gets it. I normally use the stock messenger but for what ever reason i DL'd the "Go SMS" app from the market. Made my changes to it. used it for a day, didn't like it. So I uninstalled, DL'd Handcent. same thing, didn't like it uninstalled. Now my MMS doesn't work. But to be honest i never sent a MMS message to begin with so i don't even know that it worked in the first place....looking for any help. Sorry for the short hand and probably spelling errors, I cut my finger off at work and relearning how to type without a index finger sucks.
) Play it safe install all new ROMS via instruction above
is this for zvd or zvc
This ROM is based off of the LG's ZVB
it works perfect for me just make sure you have the lcd density on 240 and your straight
Would work on C...D you can test it for us(kd)![]()
Excuse bro Hdmi is work un dis version
