JETMAKERO
I just downloaded v.04 last night lol I don't have WiFi ill wait until later to get .05
I don't Know at what time you donwloaded .04, because OG already uploaded GSE .05. and everthing is FIX.
Flashed and got same no wifi and mass reboots on market downloads
checking other links for fix
so today i visited this thread again and i see v.05 was released so i downloaded it and tried it on my phone to see if it will fix my issue but the manual programing menu still force closes on me. can anyone confirm having this problem thanx.
wifi works on v.05 awesome
Does the new v.05 still look the same as it did. or does it have a new look and theme two it. if it still looks the same. then ill keep waiting till you release the kernel and just slap that in my 1.5gse rom which is working perfectly fine on zvc
link in OP updated for v.05, all should be good now
Give it about 8min from the time I post this to finish uploading!!![]()
Ok...here is a step by step guide.
1) you are gonna want to download an app that can scale the size of the animation...i use absolute system i'm sure you can google it and find one online if you don't want to buy it. Scale it to the size that looks best to you.
2) download an app called root explorer i'm sure you can find it online too.
3) place your resized animation on your sd card where you can easily find it.
4) open root explorer and find it on your sd card and copy it.
5) press the menu button and choose bookmarks then root folder
6) open the system folder then the media folder and you will see bootanimation.zip
7) now look at the top of the screen and make sure that it says mount R/O which means that you have read/write access.
8) then press paste (finally lol) and it will ask you if you want to overwrite the original file. Press yes
9) reboot and watch an Android pissing on an apple lol
U know, u could make your own flash file with PG's new kernel all right on your phone. Just extract a kernel.zip file, download gse-c.05, extract it. Now go to the place where u have gse extracted, go to system -> lib -> module and copy all the files in there. Now go to the extracted kernel.zip file and go to system-> lib -> module and paste all the files there to overwrite it. Then go back to the extracted kernel file and zip it, flash it, and enjoy.
I couldn't get GPS, WiFi, or 4G network going when I installed earlier today. Thought u should know. Looking forward to updates...Also, if I want to donate how should I go about that?
can anyone confirm this works...cuz this is amazing lmao
installed .05 last night. seems a little quicker. maybe it is maybe its just me thinking it is but ether way i like it. havenet had a chance to test my battery on this rom too much but so far it seems good. thanks PG! but one thing i was wondering about in this version you said homeless setting was integrated but i cant find it. its not in the option for governer in setcpu. im assuming this is where it would be. any help would be great.
did you need to add anything for it to work? or just integrate it in and viola?mt's power options mod added, OP updated.
I just added the needed files from mt's zip n then my mod(s) n repackaged.did you need to add anything for it to work? or just integrate it in and viola?
Thats how I do it.I am pretty sure that I screwed the pooch in my process, but maybe it is a redeemable issue. I finally decided to make the leap to GSE-C this morning. I did a nandroid backup, and have successfully installed CSE-C v1.5. I did a restore, and up came the boot animation, etc, from my previous GSE 1.5 (the version with the Driod boot animation). I never got a chance to see what changes were made because I ended up with a boot loop.
Back to recovery and no problems there, but I am curious about how I should go about reloading my data and apps without messing anything else up. Should I do an advance restore and just restore "data"? Or is there something I missed when I was doing my backup?
