Hades (the "unseen") the god of the underworld, was a son of the Titans Cronus and Rhea and the brother of Zeus.
Download Hades_Public_Beta_v1.0
APP LIST
Added:
Battery Widget - shows battery percentage and/or temp on home screen
SuperSU
Hackers Keyboard WAAAAAY better than Android stock imo
Barnacle Wifi Tether
Replaced:
Opera Mini 7.5 (Replaced Browser)
Camera ICS (Replaced Camera)
GO Contacts (Replaced Contacts)
Custom ICS Search Widget - can change colors
GO Weather EX (Replaced GenieWidget) - better look
ADW.Launcher (Replaced Launcher2) - use with 'Tha Scanline (ADW Theme)' theme
DoubleTwist Player (Replaced Music)
ES File Explorer File Manager (Replaced MyFiles) - great File Manager
Simple Digital Clock Widget (Replaced DigitalClock)
QuickPic (Replaced Gallery3D, Gallery)
Removed:
BooksPhone
DigitalClock
EasyInstaller
Gmail
JrdPowerSaver
LiveWallpapersPicker
MagicSmokeWallpapers
Maps
MemoMobileID
OfficeSuite_Full
PicoTts
SetupWizard
Talk
TouchPal
WorldClock
Youtube
OTHER STUFF
41 notifications
69 ringtones
17 alarms
*[127 total]*
custom status/notification bar
custom bootanimation
custom poweroffanimation
custom bootsound
custom font
RECOMMENDED APPS
Set Orientation - set to Landscape (Reverse)
Display Orientator - Used to set apps to portrait or landscape if they don't work properly in Landscape (Reverse), I found Hackers Keyboard works better (for me) that way
SCREENSHOTS
*Screen shots are not stock install, I have modified mine slightly but I will put up regular screens when I have time
Special thanks to: Leslie Ann for all her work towards this. W/o her this wouldn't be possible & Dracable for all the hard work hes put into this
