Azoller1, I installed V3.0 doing a complete wipe. I don't see homescreen launcher anymore. Did you delete it on this version? As far as I know that is the only one with the circles. Also the corporate setup doesn't work for me. It keeps FC when I try to set up my account and the settings are correct.
OK the problem with the v3.0 was the new lightning zap tweak so I'm am now using the old one which is still rock solid and I still have the fixes for the issues you guys were having
Edit: just flashed the v3.0 and it works perfectly!! Exchange works and also Skype! Will upload right away!!
Edit 2: to get supersu to work first install regular superuser then install the binary for supersu then you can uninstall superuser
Thanks for reminding me of the need to re-install the binary on supersu. Oddly enough, upon flashing, I lost root. Easily enough to get back, but just not happened before. Perhaps, after continuously flashing your upgrades and new Roms, one aught to do a complete wipe. However, all is working fine, smooth and snappy and have settled on the Sony launcher. Great work.
Hate to sound newbie but whats the difference between the 2
Upgraded to 3.0 and lost root![]()
Well you didn't loose it, all you have to do is download the superuser app from the market to give supersu permissions to install its binary, I no its weird so I will probably just go back to regular superuser
Update: Added different exchange app for it to work now and also added back old SU just as good as SuperSU actually, also a few inverted apps, and new bootanimation
You really gotta stop doing that before posting the link. It's gotta darn near qualify as cruel and unusual punishment.![]()
