I'm running eclipse and have almost every tweak in pimp my Rom enabled and I get a GPS lock almost instantly. Max of about 5 seconds
I installed V3.6, but when I connect my laptop, the phone doesn't recognize it and offer to select Mass storage, internet connection, etc . (even though it is selected in the settings). It does recognize a source and charges. The PC doesn't recognize a new device, either.
Thoughts?
Thoughts?
Not to be rude, but RTFM. The first post in this thread outlines the installation process. It was pretty clear to me.How do I flash framework mod?
Does he have any tweaks in his base eclipse ROM? Does he just have init.d support?
It says:
1.Download ZIP and extras
2.boot to cwm
3.wipe data(if needed)(cache and dalvik is wiped in ROM script)
4.go to where the zip file is
5.install it and wait
5.a after it finishes installing, right after you reboot it will say some about Fixing Root CLICK FIX ROOT IN SYSTEM/XBIN/SU DONT FORGRT THIS IF YOU WANT ROOT!
6.reboot let it load up then reboot back to recovery
7.wipe cache/dalvik
8.flash framework mod
9.wipe cache/dalvik
10.reboot
I get stuck at step 8, I don't know how to do that
You need to download this file and flash it as per instructions.
CRT off animation- Dev-Host - frameworkmod.zip - The Ultimate Free File Hosting / File Sharing Service
After you click the link on the second post under MODs, it will appear as framework.zip
Download the file in post number 2 marked "CRT animation"
You guys are quick! Lol...
I wouldn't mind having my Verizon mobile back. It's the only bloat I used. Nice to see data and check out plan usage. Titanium doesn't seem to like restoring factory set apps
Can anyone confirm if the Corporate (Exchange) E-mail is working yet for this ROM? This was the only thing holding me back in previous versions. I would give it a try myself, but can't afford to be out of touch with the office for that kind of time.
Many thanks!
You can download my Verizon from the market. That's what I do.
GPS does not work on v3.6?
Every time I open google maps, it force reboots my phone.
Anybody else having this problem?
