I have 3 files in that folder. What is dropbox? I don't seem to have that app.
Dropbox is an online storage service. You have to sign up for an account and then you can store files in the cloud. You can also use it to sync files between your computer and your phone.
Sorry you were insulted and/or offended, Azoller, but if you go back and re-read my posts, you'll see I said as much good things about your ROM as I did not-so-good things - and for most of the not-so-good things I was pretty clear that they were my opinions.Stackrat said:[REMOVED BY STACKRAT]
You're not going to get awesome battery life and awesome performance at the same time (though the stock ROM does a great job at having crappy battery life and mediocre performance!).
an update on the new version, i added some more inverted apps and different init.d tweaks and build prop tweaks, added some cool new launchers only have 3 launchers, added some cool new mods, and also have done some blue themeing, and also updated a few more things, and lots more to come in the next few days, will probably release it thursday or friday, maybe even saturday(for the themeing to be finished)
I hadn't thought about freezing it first. I'll have to give that a try when I get some time again.Stackrat it worked.
I went to Rom toolbox and froze gmail. Then I uninstalled it. Restarted my phone. Installed gmail from play store. It started syncing and force closed immediately. Opened it up again and it had synced all my email and has been receiving email normally.
You had every right to get defensive. I would have done the same if I were in your shoes. ...and in the past few weeks, it would have been much, much worse! Thanks for your forgiveness.Its all good sorry if you felt like I attacked you I guess I just got angry but its all good now! Thanks blue racer for trying the gmail thing!![]()
I just had a thought. Would it work if I replaced the gmal apk in the zip before installing the ROM?
I actually tried that first and it didn't work. In hindsight, I think the issue was that I probably had a version mismatch between GMail 4.2 and 4.2.1. I think if I had frozen the app first, cleared the app data and cache, then replaced it - it probably would have worked.it's easy to replace the inverted apps with stock ones. Just go to system/apps folder and drop the apk in there and reboot and you'll have the new apk. DO NOT INSTALL IT LIKE OTHER APPS
