Lykarsis
it's easy to replace the inverted apps with stock ones. Just go to system/apps folder and drop the apk in there and reboot and you'll have the new apk. DO NOT INSTALL IT LIKE OTHER APPS
When I first started using eclipse I didnt like the inverted play store (which I actually like now) and I just downloaded the latest play store off xda and dropped the play store apk in system/apps and then rebooted and boom! I had the stock play store again.
I must thank neph for teaching me this though, because I kept trying to install the apk and it wouldnt workand neph showed me the proper way to do it.
I assume the same applies if you want to add inverted apps?
Thanks again!
May just buckle and give up BT, considering the current interface... -_-
