phillip_viado
Aw you didn't add the crt animation?
downloading much faster than before on dev-host thanks
Does this ROM have Google Ears built in?
Also, pretty sure i know the answer, but... anyone have bluetooth working on this ROM? I love what I'm seeing, but I've gotta have my BT...![]()
My phone doesnt give me the option to select usb mode when I plug it in now. When it happened before, I rebooted and the problem was fixed but 3 reboots so far and the problem is still there. Any suggestions?
Agreed. You can still clear caches with system apps, but you might not be able to null do it within the app, so you'll have to rely on apps like rom toolbox or titanium backup.I thought about that when I did it. I'm still testing it, but I also clear my caches so often (manually), that for my use, it shouldn't be too bad. However, I wouldn't recommend it to anyone else without more testing first.
Well the best way to flash this is take the OTA update then unlock then do full wipe then flash, did you come from v6?
No, I did not. Working on that now, but did not know to do that.
Also, looks like you said that Bluetooth is not working? Might want to list that on the Issues on the OG post.
he wasn't saying you need to come from v6, he was asking if you had because it has not been tested with flashing from v6 and therefore that may have been the reason why you are having issues.
I am not pointing fingers, but if a rom--regardless of reason--has something not working, it should be listed. I loaded this ROM vs another because this one did not list Bluetooth as an issue where another did. Based on the Issues section, it would appear (to the less experienced) that everything is working.Bluetooth is an issue with all the roms other than pure stock v7. Once you unlock the phone it kills the bluetooth. That is why he didn't list it in the bug section because it's not a bug with the rom but it's a bug with the phone being unlocked.
Type the word, click and hold it (to highlight) and then select add to dictionary. It gets up to trying to add it to the user dictionary and then Settings FCs.
Did you keep it in once you rebooted? Keep it in the whole way, and always click on USB mass storage because sometimes it wont say USB plugged in you still have to click it in the connectivity settings
I kept it in the whole way, it doesnt give me the option to change the usb mode
Which USB cable are you using? The one it came with?
No, but I've used this cable for a while and it has always worked. I figured that the cable might have messed up so I tried two other cables and still the same.
That might be the issue other than that I'm not sure did you flash this from v6?
I'm not sure, what would be v6? Sorry, I'm kinda still new to a lot of this.
