Root [ROM] [MikRoms] The Perfect Storm v1.4 [04-23-11] Thunder and Lightning!
i like this rom pretty well,but had a random reboot,plus some extreme lag when opening the message app that was so bad i rebooted it.
just thot id add this... i had flashed drods 1.5 kernal and reading thru that thread,found someone else that had a reboot when trying to answer a phone call. since thats when my reboot happend also,i think its a pretty safe bet the kernel with the culprit.
so the only issue i had was the messaging app lag,wich was fixed with a quick reboot.
Flashed the update .last night and let me say this.. DAMN. Everything is sooooo smooth, as if everything is 60 fps smooth. All minor tweeks are beautiful as well. Fantastic job good sir, well done.
OK One question... can you flash this if you are not in firmware 1.12.605.9 but instead on Firmware .6? you cant be too careful... thanks... sorry for the noob question,,,
Just want to make it very clear that I have nothing to do with this project. All credit goes to TeamMik!! I just wanted to update this thread since I'm the OP of this thread.
As long as you are rooted with a custom recovery like Clockwork Recovery, firmware is not important. This ROM is in update.zip format and can be flashed no matter what firmware your current ROM is using.
This is not my ROM I just noticed it over at XDA and thought I would post it here for others to see. It is based off of the .9 RUU. I haven't flahsed it yet but I will be shortly. All credit for this ROM goes to chingy51o!
[ROM] [MikRoms] The Perfect Storm v1.1 [04-3-11] Thunder and Lightning!
Features
  • Odex rooted rom based on the 1.12.605.9 RUU (Yes, I can do mods on this; Way way way way faster then deodex. Not to mention the boot times are ridiculously fast)
  • Adrynalyne's 2.0 Kernel
  • Bloat Free
  • Semi-Transparent 5 Column App Drawer
  • Zipalign on Boot
  • Tweaked System for better Battery Life and Performance
  • Rebuilt all packages to ensure minimum amount of useless files in them to ensure maximum optimization.
  • Themed Gingerbread Keyboard
  • Themed Semi-Transparent Market
  • Themed Gmail
  • SD Card Speed Fix
  • Max 32 Tabs in Browser (Thanks jcase)
  • Updated Hosts File to Block Ads
  • Malware Patch
  • Added Custom Sounds
  • Custom Animations by aamikam
Included Apps
  • Wireless Tether
  • Facebook
  • Adobe Reader
  • Themed XDA App
  • Spare Parts
  • Quick Boot
Changelog
April 3rd v1.1:
  • Rebuilt and Optimized All Packages For Best Performance
  • Odexed All of the system apps
  • 100% Working 6 Signal Bar (Thanks to sk806 for helping me out with this!)
  • Removed Recent Apps from Pull Down
  • Added Transparency to Pull Down
  • Tweaked Rosie Scrolling a Bit more
  • Added Smooth Battery Charging Animation
  • Hidden GPS Icon
  • Hidden ADB Icon
  • Added HTCSense.com Support (Thanks Adrynalyne)
  • Added some of Adrynalyne's Tweaks
  • Disabled Boot Sound
  • Added a Themed Dialer
  • Added Rosie Settings to Remap the Right Button
  • Renamed "People" to Contacts
  • Reverted Back to Stock HTC Clock for those of you having issues with skins
  • Made App Drawer Text Smaller So the words dont look so cluttered (I can increase the side for those of you have bad eyes, just ask)
  • Updated and Re-Themed XDA app
  • Set max browser tabs to 32 (thanks jcase)
  • Made toggle widgets background transparent
  • Themed Google Search Box
  • Added Radio Settings to Settings (Thanks jcase)
  • Fixed Market Not Showing All Paid Apps Issue
  • Added a whole bunch of love... haha
  • And a whole bunch of other things i cant even remember anymore. been working on this too long...
March 22th v1.0 - Initial Release:
  • Began APK Optimization Process (Going to take awhileeeeee&hellip
  • 100% Battery
  • Improved Rosie Scrolling
  • Removed all bloat from the rom (A 130 MB Golf Game? Really Verizon?)
  • Updated All Apps
  • Patched Superuser (Thanks rmk40)
  • Pretty much everything in the features section...
A Full Wipe is REQUIRED before flashing this rom. If you choose not to do this (for who knows what reason) please do not post any problems you are having!
Please note that because all apks have been optimized and rebuilt for maximum efficiency, themeing carelessly will break these optimizations
Not only are you super helpful but you may just be a GOD!!!!!!
Thank you so much for all that you do.
Features
  • Bloat Free
  • Zipalign on Boot
  • Themed Gmail
  • SD Card Speed Fix
  • Malware Patch
Included Apps
  • Wireless Tether
  • Facebook
  • Adobe Reader
  • Themed XDA App
  • Spare Parts
  • Quick Boot
Changelog
April 3rd v1.1:
  • Hidden GPS Icon
  • Hidden ADB Icon
  • 100% Battery
  • Updated All Apps
Hey PAPA,
To install this newer version, do I first need to install the 1.0??
Also, when I finally download this,I trust I will lose all my info that I don't have stored on Titanium, is this correct??
I am using the
[KERNEL] [Sense] 1.76 Ghz OCUV/VDD sysfs/EXT4/BFQ/TUN/CIFS 01/04/2011 on the stock T-bolt rooted software. It seems to be working fine. Do you recommend this for "The Perfect Storm"?
Thanks
Hey PAPA,
I am using the
Thanks
No you do not need to install 1.0 to use this. And yes you need to wipe data and cache before installing. Make sure your Titanium backups are up to date. I'm using the kernel that comes stock with this but there is absolutely no reason the kernel you have listed will not work. Make sure you do a nandroid before flashing and you should be all set.
I was great until you said nandroid. What is that??
IDK if it is me, I was getting an FC every time I tried to access the phone. Not an Automatic FC, but when I hit the phone, it would hang for about 45 secs, then I would get the FC.
did a full wipe / clear cache / clear dalvik.
btw, if i were to go from V1.0 to 1.1 do I need to do a full wipe again?
chingy usually reccomends full wipes. i tried to flash a incredibly re-engineered update withouta data wipe on my incredible and wifi dint work afteward :mad: it doesnt hurt to try it,but make sure you make a backup,and realize that if things dont work you may be back doing a fresh install anyway. :)
Any one know how to put the normal icon on the right from the dock and make it do the normal function instead of the browser ect...? am running this ROM and i dont mean to be mean i do like the rom and enjoy it but i dont like the function to launch the browser.. ect... not trying to insult any one in advance..
Best bet would be to go to the thread on xda and ask chingy to make a stock rosie zip for you. The rosie is the stock sense launcher (apps, phone, customize)
Apparently this ROM has been updated again. I can't wait to try this out simply for the new kernel!! OP has been updated.
Anyone know why the thread is locked and the download link is disabled for this rom over at XDA? anyone have the link cached?
EDIT: Never mind i found the download. Still curious why its locked.
Where did you find it at? Looks like they deleted the link. Thanks!
well shit... I hope something isn't horrible about it... I downloaded it a few hours ago... and just finished installing it!
I checked... and you're right... link i click on their page isn't working now
EDIT: Thread locked as well =(
Over at his forums, he said the XDA thread was locked because he linked to the download page in his forums. He isn't too pleased. It wasn't locked because of any issue with the ROM
theMikMik.com • View topic - XDA Thread Locked
Just installed 1.1 yesterday now just finished up 1.2. Reloading my apps.
I love how you can now find the bootloader, etc... on the turn off menu!!
I hope its fast. I had the 1.76 in the 1.1 and it was a little slower quadrant wise than stock.
That's ok... I really don't understand what the quadrant purpose is but the dna etc...is cool to watch
WHOAAAAAAA!!
This is unfu**ing real!!! This new rom is nuts!!. 1.8GHZ!!
Great additions and I MEAN GREAT. Fast as Lightning and quadrant score of 2956 at 1766mhz.
GOOD LORD!!!
UNREAL!!! A genious at his finest.
THANK YOU SO MUCH!!!
Tell me where to donate!!
