NEW FEATURES
03/03/2013
∙ New "init.triumph.rc" and a few other boot.img-ramdisk changes.
∙ Updated Vendor Proprietary Binary's, mostly BT/WIFI related files.
∙ Cleaned up GPS hardware and config.
12/28/2012
∙ Fixed issue connecting wifi & Bluetooth at the same time
12/27/2012
∙ Using Bsydz updated CM7 Kernel
∙ Added Bootsound functionality
∙ GPS Hardware changes including used libraries and AMSS version
∙ Updated droid fonts
∙ Removed all previously added a/v files and added the Video & Audio files used in the Cherry variant.
10/15/2012
∙ Updated to the Sharp 2.3.5 wlan firmware and init.qcomm etc scripts
∙ Removed system prop line for video suspected of causing wifi issues for some users
∙ Completely reworked the init.triumph.rc.
∙ Removed all the froyo mm modules
∙ Add Sharp 2.3.5 mm modules
∙ Replaced static CM7 wallpaper
09/26/2012
∙ Flicker is back
∙ Camera/camcorder are now working correctly
09/23/2012
∙ Flicker who? Flicker is GONE!!!
∙ Better video
∙ More stability
09/21/2012
∙ Major improvements in video 19fps
∙ Multiple libs replaced to help with more stability
09/15/2012
∙ Replaced multiple lib files from WelcoM, Sharp, Andro-ID
∙ Updated gps.conf
∙ Updated system.prop
08/19/2012
∙ Removed libaudioeq.so was causing notification fade outs
∙ Fixed blank screen after other caller disconnects a call
∙ Disabled surface dithering, can be enabled in CM settings and increased dalvik vm heap-size for better performance
∙ Restored Tickerguys values with memory99 which helps with gaming
∙ Added fix to resolve flicker with hard buttons
∙ Added bootup sound script
08/10/2012
Reimplemented Audio Fix (Notifications don't mess up sound anymore) didn't work
08/09/2012
∙ Updated GPS it's faster and uses less battery power
08/08/2012
∙ Camera fully funtional
∙ Removed volume tweaks due to distortion
∙ Updated GPS
∙ Removed some libs to add better battery life
08/06/2012
∙ GPS speeds are simply unbelievable!
∙ Rear Camera Picture & Video works
∙ Front Camera Video works
∙ Removed Alpha HDMI Code (broke camera)
∙ Added Live Wallpapers
∙ Updated media profiles
∙ Updated egl drivers (23.6 FPS Nenmark 2)(31.5 FPS Nenmark 1)(55.7 FPS NeoCore Qualcomm)
08/01/2012
∙ YouTube HD now working perfect go watch The Hobbit Trailer (
flicker in portrait)
∙ Videos seem to be playing perfect in default stock player now (
∙ Camera photos now saved in folder 'Camera' no more 100ANDROID
∙ Photo names are based on date and 24 time including seconds i.e. IMG_20120801_140807
∙ ROM is feeling much more smooth as gralloc looks to be working correctly now
∙ Added in Volume adjustment found by
jarjar124.
7/29/2012
∙ Fixed video flicker
∙ GPS even faster
∙ Removed specific settings not needed for Triumph
7/26/2012
∙ Place mp3 in /system/media/android_audio.mp3 for boot sound on boot up
∙ Screen dims out before timeout
∙ Clock has had edits to look nicer with larger font
∙ Added opencore files for media playback. Use MX Player with Software Decoding for best experience
7/25/2012
∙ Audio completely fixed, no more issues with notifications killing sound
∙ Increased 3g speeds
∙ Increased GPS lock speed
∙ Haptic touch works on notification window for turning on and off hardware more quickly
∙ Bluetooth Faster on connections and re-connections
∙ Automatic Brightness is instant, just use Settings < Display. No more tweaks needed using Cyanogonmod Settings < Display
∙ Video performance increased try out
Holo Launcher with Scrolling Cache < High Quality
∙ Color effects now work on Back Camera (Sepia, Negative, Solarize)
∙ Better keyboard response
∙ Updated build.prop with wifi, battery, video tweaks
∙ Alpha HDMI support
