dsmryder
Android Expert
would it be possible to implement this ?
[HOWTO]More smooth scroll & volume step increase for MOST android phones[Poweramp OK] - xda-developers
edit:also seems like vibrate doesn't work?
I couldn't tell you about the vibration part, mine works perfectly. Might be a setting or a bad flash. Check your settings first.
As far as the "smoother" steps, that would be easy. I'm not sure if it should go into the CM7 side or if it can be "updated" via an overlay thing. G60 would need to chime in on that part. I did find out where it would go, though.
