TheBritton
Resident Galaxy Cat
Okay, thanks! Downloading now and will try it out shortly
Okay, thanks! Downloading now and will try it out shortly![]()
I used MX based on a conversation I had with Izzard and tested with that. It's very possible Mobo will be just as good as long as it can do software decoding. Since the stock player doesn't do software decoding it of course plays like crap.
Great rom, guys. loving the experience. No major issues/bugs so far, but if it's not too early to start requesting a few features, there are a few features from other roms i kinda miss.
1. option to show battery life as a bar at the top of the screen.
2. option to hide alarm notification on status bar and lockscreen.
3. option to center status bar clock
4. Use a hardware key (usually long-press menu) to turn on torch.
yay smoother scrolling and volume adjustment is implemented!! g60 i have a question, do u ever plan to build with linaro? i heard and experienced linaro on my n7 and it improves overall performance. I'm not much a dev myself so I'm not sure would it be possible..but hey...this is android...almost anything is possible! great job with the rom!!
edit: sorry if I'm asking for too much..but would it b possible to implement this?
[HOWTO]Implement Swipe to Remove Notification - xda-developers
Swipe to remove Notification is there and it works with no issues.I think that's already in there. Can someone tell me if I'm reading the link wrong?
G60, thank you for your continued efforts to make this phone awesome, you've done an amazing job.
One thing though, since switching to this rom I've had a handful of random reboots, although none since I installed the most recent update. When I initially installed this rom I did a full wipe however I did use titanium to restore apps and system data from you're old version of cm7.
I was wondering if anyone else was experiencing this or if it was something on my end?
Thanks!
Has anyone else noticed their machine running a little warm? I noticed it for sure after the 7/29 build. My whole machine just feels a little toastier. Also the battery is draining at about 25% / hour (yes, 25% per hour). I have not changed any settings that I can think of, just all normal use. I do not have it overclocked.
Any ideas?
I'll try the 8/1 out, but if it is the same thing I'll have to roll back a few releases and see if it is still happening then.
Another note is GPS. It locks it 2 seconds and then it starts blinking, like it give me preliminary position and then just double checks if it was right the first time. Still way better than stock!!
Wht is the differance between this and g60's....... they are both 7.2. Just wondering
does this rom take advantage of the speed fix you posted about removing the two lines in build.prop? I don't see them in there, but I'm getting speed test results that are back to before I did the fix on the old g60. Could be a network problem right now, but I thought I'd ask. Is anyone else seeing slower speeds or just me?
Can anyone else replicate this?Is this ROM stable enough to replace g60?
