It's coming, I sware!
Another release of this or a new ROM?
Both. CM10 will be out later today. We also have a new update for CM7 coming.
Nice, ill be looking forward to see whats up later on, also i just wanted to thank you G60 for keeping everything up on your site, will i know its like the Devteam site now but it started as yours and its just good to know everything is in one place if i were to ever need it
Are any of you that are having problems with the WiFi toggle on the power control widget using Titanium Backup or another backup tool (if there is one)? I was using Titanium to backup and restore my app and system settings and didn't have any problems until this ROM. I tried to adjust my screen brightness with the widget and nothing would happen so I went into the display settings, checked Auto-brightness, chose OK, but it didn't take. I opened it again several times and saved but it was always unchecked. Then the widget wouldn't work at all for brightness.
Lesson learned as now I just backup my apps and do the system tweaks manually after a flash. You may want to try that if you're using backup software.
Awe yeah, he's awesome isn't he? He invited me on the team knowing I don't known a ton. And after that, helped set me up with the new system and sent me some parts too.
Yea, I had seen that on the other thread, you guys are almost all rocking the same PC rigs, its awesome, I was just browsing the site tho and noticed everything is there lol, like every g60 cm7, all removed apps, devteam cm7,9 and 10, the cyanocream theme, flash, and a backup download area for the gapp
I am having this problem as well. camera shutter mute is one and background data are commonly unchecked after checking them, requiring reboot to fix background data but, nothing fixes camera mute.I have had boxes/settings checked and then come back to find them unchecked again. I have found that after checking a box, restart your phone for them to stay checked.
I noticed that you didn't include tun.ko in any of your roms. I ended up pulling the module out of an old Ticker rom and VPN is working fine now. You might want to add it to your next release.
I'm off to college myself soon. I have to take all these annoying basic computing classes first, but as soon as I get coding down in Java and C, I'm sure I will be able to assist one day.Hey G60 don't know if it will help at all but I just got a 2.6 quad core Macbook Pro. I have zero coding experience, but am willing to help where I can. I will be starting school here shortly for mobile development.
Harford Community College for two years, then hopefully a scholarship to VCU.Where are you going to school if you don't mind me asking?
.I just started learning Java as well. I'm learning on my own though because my school dropped the class due to budget cuts.
I love that these ROMs are open source, it's good for those of us who are learning.
Also I was wondering about the screen flicker problem, do you guys know what's causing it etc.? It seems like all Gingerbread ROMs for the triumph have that problem(I haven't checked out Minimal Triumph 2.0 or Gingerbread 2.3.4 though do they screen flicker issues too?). Also I haven't had a chance to flash CM9 but screen flicker isn't listed as a bug there so I'm guessing it doesn't occur in CM9? I know it's a very minor problem but it can get frustrating at times.
Thanks for your hard work MTDEV and I love how organized everything is in your repos its very beneficial to beginners.
yeah we might have a beat on flicker. Chairshot has been working on some new stuff for 7. Hoping to get it out soon but still having some problems with the code. I'll be cranking on the kernel tonight and see if I can't fix some stuff.I am still not able to change the buttons in the notification power widget.
