b_randon14
Android Expert
Definatly the 19 build has wifi issues. I could never get it to connect to my network, then it started erroring out enabling wifi. Wiped system and flashed back to the 10 build and wifi works fine.
Uh oh... a new project in the works...
Just wondering, since currently the keys don't light up if you can add the keys to the screen like you could on Mantara's CM9 in the tablet tweaks section. Unless this already exists. Thanks
The buttons light up.
By default, they are turned off above a certain ambient light level to save juice, since they are screen printed on the glass and do not need illumination in daylight.
You may change them to however you see fit.
If they don't light at all on your phone, they may be broken/malfunctioning.
I was running the TG Reloaded ROM with issues, then switched to CM7.2 20120819 and everything seems to be working fine. I see that the button lights at the bottom turn on / off, maybe even flicker, and sometimes short "LOL" texts fail on first try, but I can live with that. EMail, WiFi, Compass, and Battery life seem excellent, though I am a light user.
I have little experience with Phones, but on other equipment I in which I Flash Firmware / ROM / Images, finding the complete "how to" instructions is usually the key. I have read several posts with different things to reset / clear / wipe. It's easy when you have a little experience, but coming from a Phone Noob, it's not, but it has been a fun learning experience.
S far as ROMing our phone, that's like the one place where Motorola got things right. Our phone send to be the easiest to ROM.
The problem I have ran into is my WiFi wont stay off. I have tried the widget to turn it off and in the settings. It will turn off but turn back on in a minute or two. This does not hamper the phone when away from the house because 3G will take over once away from my WiFi. But it does drain the battery quicker.
Same thing is happening with GPS as well. Using Build 20120819
I think I may owe G60madman and the MTDEV team an apology. I did some testing and believe I discovered what was causing my issues. I believe it all was due to ADW Launcher Ex. I was having the same issue with this ROM as I was having with CM9 (missed calls and SMS) and it seemed to start AFTER I installed the launcher.
I re-flashed the ROM and we will see if things work better.
Please forgive me and my incorrect reporting :stupido2:
I don't believe that your WiFi issues are due to ADW Launcher as I have the same problem with WiFi not staying off and I don't use ADW and never have.
). I never cleared the cache before so that might help too.I love it when I find out that I'm working on something that was already done.
For those who want the soft buttons to stop flickering, go to settings--> CyanogenMod Settings-->Automatic backlight--> and the first check box is to put a buffer in the way the phone handles the light sensor. Have fun with that.
So far I haven't gotten any of the wifi issues that people are complaining of on the 0819 build. It looks to be a legitimate issue as so many people have complained about it. But for me this build has been completely smooth. Maybe I'm just lucky
i wiped everything on two installs, had wifi issues, blank screen after call issues and and tethering issues. first time i had awd install second didnt, same issues. in fact second time all i installed was titanium.
where can i get old versions of the rom?
