sqwerl
Thanks, i appreciate the help. Any idea why this is a problem for some?
Thank YouHello yall, Been a long time reader/lurker, so right off the bat I want to say thanks to the great Dev community that keeps pushing foward to pick up when others jump ship. You all are all saving me alot of $$ keeping me here interested with the Triumph.
Anyways,
Problems I am having...
I use the same app for my messages. I can tell you that even with the same release, I haven't had an issue other than when I load fresh and I get a new message that the new message can get lost during the restore process. I have had issues with Handcent. It doesn't always get all of the messages. I will open the restored messages with the preinstalled app and change my settings from there so I have all of my stuff the way I want it.1. Issues with restoring SMS. I've been using the SMS Backup & Restore App since November of 2011, I have flashed just about every rom out there & have never had this problem until I flashed mtdevCM7-20120819. I only was able to restore about half of them, I rebooted & they are now all gone. The other day I was running mtdevCM7-20120810 & I didn't run into this. Any suggestions?
Different ROMs can have an effect (affect?). Also a bad download or flash can have simular issues as well.2. Data- It seems like my data for SMS is intermittent. I'm sure the fact that I have horrible service right here @ my little workstation doesnt help but I'm getting messages that are hours old & again, that has never been an issue since I've owned the Triumph. Will some roms have different connection configurations when it comes to 1x & 3g running together or separately or will they have different PRL's?
This one is kinda wierd. I was using a GPS faker app that would mess things up while using the real GPS. I think it was how the eupherics (I think that's what it's called) is used.3. This is an odd one & maybe I'm paranoid but when I open Google Maps it automatically opens up on Nigeria instead of the U.S.. If the last time I was using maps I was on my home wifi would that mean that my networked is POWNED by someone possibly using a RAT in Nigeria. I ran Z-Anti app (pentest tool/network discovery tool) & didnt see anything odd on my network. On Google maps there was no big blue circle or blue arrow, it just opened to Nigeria. I enable the GPS but it wouldn't lock, even with the wifi. Just seemed odd.
So I believe that is it for now.. Any input would be greatly appreciated & I aplogize ahead of time if this has bee discussed already & I dont remember it.
Heres a total noob question, but if I had a kernal running from a Froyo based ROM like Froyocream or B_Rom running on B_Kernal 2.3 does that get wiped out with a Davlik & factory wipe? I'm under the impression it does but what should be run with this ROM? Any suggestions? They aren't all compatible w/each other ROM & Kernal wise, correct?
just double checking, the default mtdev-cm7 20120810 governor io are interactive and sio... right?
Can you download it with your phone's cell data connection instead of WiFi?Does anyone have a different download link for this? My apartment complex wifi firewall keeps blocking the one in the OP for who knows what reason and I really wanna try this.
This may seem to be a redundant question. But is there a way to enable Wi-Fi during sleep mode? After 10 minutes or so of it being asleep the Wi-Fi disconnects.
Thanks for the help![]()
Ugh having some problems and hoping someone can give me a fix. Just flashed the new CM9 build and it was working great, followed all the instructions prior to installing (did factory reset, formatted cache, cleared dalvik cache. Then I just flashed the thunderprop for ICS and it installed fine but when I reboot, my phone keeps giving me the message "unfortunately, the process com.android.phone has stopped" and shows no service at the bottom of the screen. Anyone have any idea what went wrong and how to fix it? Where can i get the stock build.prop file? Maybe putting that back will fix it?
