Only issue on this ROM's current stable build that irks me a little. Nothing against you guys, but I can easily live with the other minor bugs while you work on CM7. g60madman, if you could, please figure out what's making the GPS jump from location to location. Note that this only happens to me when on data and AGPS, Wifi works great with location features. Problem is, if I ever need a GPS, I'm never really near Wifi. So basically AGPS needs a fix, and this was no issue with CM7 g60style. Maybe it was CM7 that borked something? Or you guys need to revert one of the changes to the GPS libraries? Tried using FasterGPS to no avail, GPS still jumps around and will never lock in. Anyhow, enough complaining on my part. Madman, if you need help pinpointing the commit that caused the issue by having someone test each build, I'm all ears. I'm willing to backup my current setup and test away until I find the latest build with an accurate GPS lock. That should help you guys out a bit.
