That's no good.Glad I haven't tested it yet lol.Check the site. It might be up before I post this. It's simular to the last tester except I moved Settings.apk.
Never mind!
I loaded the wrong ROM last nite. The new tester doesn't have a working Settings.apk
I think I've found the cause of the init execve error, I added some extra logging to init:
init: cannot execve('/') for rmt_storage: Permission denied
And it looks like in init.triumph.rc there are some extra spaces around the rmt_storage stuff on line 265. Trying a build with those extra spaces removed.
EDIT: Yep, that seems to fix it. And maybe rmt_storage wasn't running before? Not sure what it does...
I hadn't noticed that the errors were gone in PA, now that I look, I had changed that line. Thanks for pointing that out.I think I've found the cause of the init execve error, I added some extra logging to init:
Now we just have to figure out why the wifi is rebooting the phone.
WIFI works fine, but the kernel oops/random reboot is always the tainted libra/librasdioif. Even when it is an expected reboot like Shadowgun: DeadZone, it gives the tainted libra/librasdioif error then the kernel debug info then kernel panic. The debug info does change depending on what is happening at the time. I am trying to learn more about how to debug the info from the last_kmsg but it is pretty complex. It could very well be a memory leak, I figure the more heads the merrier. I want to see a solid ICS ROM that is stable above all other things.I didn't know wifi was rebooting the phone. I had enabled it to download a few apps and it was working, but I didn't have it on for long.
What I have noticed, is some kind of memory leak or something. After being on for several hours, and trying to launch an app, it will usually 'hang' for a longtime before showing the applist, then will reboot the phone when I pick an app to start. Then, it gets hung on the loading screen until I wipe both cache and dalvik from recovery.
I know u guys are probably tired of hearing this but..Thank you For all the time and work you guys have put into the rom and getting this camera working![]()
That is why I have been trying to get the touchscreen drivers from the M410 kernel working, as that made a huge difference with Sharp, U9000 and CM7, but the changes needed just aren't working with ICS. Plus the update fixed the lines in the screen that is seen with some phones. I can update all the related files with no issues, like atmel_mxt165 and synaptics_i2c_t1320 also the corresponding files in include/linux. The only one I can't get to work is bi041p_ts, I have read all the touchscreen porting threads and have compared the files between CM7 and CM9, which you probably saw was just the pressure lines. Which is how tjstyle got it working on the M410, but he did it in the bu21018mwv file. I don't think it has to do with the .idc cause we use the same one from CM7 with CM9.
Any way, I'm rambling, so any info or bouncing ideas is definitely welcome.
Check out this thread, third post http://androidforums.com/triumph-all-things-root/655402-dev-bsydz-triumph-x6-port-encylopedia.htmlUsing force module load is probably a pretty bad idea... if any internal kernel data structures change, it can cause crashes and other problems.
When you talk about the m410 kernel, which one is that? I see you talk about it in your kernel thread, but I can't tell where it's from.
I think the goal should be to have a set of blobs (libcamera.so, libra.so, whatever else depends on the kernel and certainly any kernel modules) matching a vendor kernel version ("stock" kernel). Maybe that is what you are trying to do with m410.
Long time lurker here finally decided to register....I sent in $20 to cover MTDEV's costs. I cannot do this all the time, but I encourage others to spare $5 or so when they can.
Hi, first I would like to start saying thank you for all the great work the MTDEV is doing. I have been using CM7 for quite a while and and have been loving it.
This weekend I have decided to update my Triumph to CM9 and for some reason, the phone says "no service". I came back to CM7 and everything is working fine. I have also installed CM9-ALPHA (multiple developers) and it worked too.
However, I really want to use your version and I am wondering if this no service thing is a known issue. While tweaking on my phone to find a solution, I have noticed the phone cannot go out of airplane mode.
I have re-installed CM9 5 times but had the same problem every time. I have wiped the Dalvik Cache on the last two install as I thought this could help, but it did not.
Do you have any idea, on where does the problem come from?
Thank you for your help, your great work and your time.
Download and flash the 2/23 build, the link is a page or two back
Thanks, budI was looking for it in this thread.
I'm having trouble pushing my commits to MTDEV git, so I have made another testing build, with the orientation fixed:
Mediafire:
CM-MTDEV9-20130223.zip
Mega:
https://mega.co.nz/#!SAUnjYqA!W4AUcgRT9-CYX6uWNDtpOwx8AlByhiZPtmTb4gpTjQM
