Is anybody having trouble with the build in the OP, on the main site. Not one of my testers, in the tester folder? I knew that I may have failed testers, that's why they are off to the side.
Went back in and added index.php to the tester folder so it shows the MD5 for items in that folder.
I believe that somewhere on here there is a note about that build not having data.I never tested it myself so idk.I'm sorry, I searched the thread for 'no service' but I could not find a definitive answer to my question, just some stuff about the camera not needing service to test... So, I'll try to post my question and see if I can get a better answer.
Using the MTDEV-CM9-20130218 my phone does not get service, I don't see this being in the release notes for 'not working'. I've tried re-flashing a few times now with no different results, still no service (data or cellular).
Does the 20130218 build have working cell service including data?
Hey All,
Just trying to load a build on and wanted to know which is the most stable build with the working camera. Been away for a while and wanted to catch up. Great work by all for continuing dev.
Thanks,
bidzer
I think that with current work it would be better to hold off until the next release is done. I'll probably post a test build this weekend as we would need stuff tested anyway.
Thanks, I'm just looking to load something on my phone which will be there for a while. I like romming but I need to get something on there permanently![]()
Long time lurker here finally decided to register.
Finally progress has been made with the camera and that we might see the end of the tunnel
I have $25 or so in my paypal that hasn't cleared yet but once it does I will be more than happy to donate for the cause.
And please hold me to this! I don't want to forget and not donate![]()
I am having same issue with 2/18/13 build as well with Data/Service - Tried to toggle Airplane mode for which stuck on Airplane mode ON and will not come off.
I switched back to 11/13/12 build and flashed the camera for which works on camera but unable to take pictures without it crashing (was same issue in 2/18/13)(My biggest thing was to have the LED to work so I could use it as flash light :-D for which it does after the flash update.) But I am sure you guys are aware of it any way. Keep up good work :-D. I can survive without taking pictures for which I can just carry around my 10mp digital camera until you guys really hit it off :-D then that is totally awesome of you guys making your way through developing the mod!
Hey, for anybody who cares for it. I remapped /hidden/data to /sd-ext. It opens up some space for us to use. What I plan to do is use BSidz's gapps and modify it to make use of the space that isn't used on our ROMs. I will probably remap it to somthing else. What I was trying to do was almost foolish as the gapps aren't changing unless I update them. And even with that I wouln'd need to change anything else other than the app it self. This is a learning experiance.
New ROM after I fix my mom's computer.
I just flashed over to adamto's CM9, and I'm experiencing some issues getting the camera application to open. Most of the time, I get a black screen before an FC, but on rare occasions, it actually goes through and works. Anyone else experiencing the same issues?
What does opening up space in this context mean? Space for what??
This stuff isn't on ramdisks is it? I have been wondering where all of our ram is...
I think he means FC=Force CloseYou mean the front camera works for you sometimes??
I know I haven't.Only time I ever got black screen is when I tried enabling video on Skype then I would get that black screen when I go back to the camera app.Every other time I never had issues.
