whats some of the features this rom offers over others.
We wanted to do some different things and we hope you like it
I am running the Slayher 1000 kernel. Getting same battery life as with other 2.2 roms.
I like everything about it except the lock screen. I don't like that little swipey thing at the bottom like UD has. That's what made me switch from UD. Oh, and I don't like having any words on my screens that I don't put there myself or allow. The word Sourcery is on my lock screen and I don't like it.
Otherwise, I like what they're doing with the swappable fonts and themes. You can tell a lot of work went into it.
I'll keep it for a couple of days and see how things shake out.
-L
can't get it past the google introduction screen....the one that tells you to touch the droid to get started.....
yankee now i know where you hang out. if you do a restore from titanium backup or such youll have to run fix permisisons its avavilble as an option in the settings.
Also the reboot issue i mentioned above is fixed. We will try to get this out this weekend.
