Shawnsac2000
Loving the rom, who do I use PlayStation Certified?
I've been using this for a few days and can't send mms. I can receive mms no problems. I'm going to try gosms and see if it's the messenger apk
There is a fix posted in the thread. You just need to change MMS connection settings
Wonder why it was set to TMobile in the first place ?
**MMS working After This**
Thanks to heythereitsv and all the guys in this thread http://androidforums.com/evo-v-4g-all-things-root/621181-project-get-mms-working-aosp-aokp-cm-miui-builds.html
i started messing around with the settings and was able to get mms to send and receive.
I got mms working by just changing the mms settings inside the text msg app and using this address --> "http://mmsc.vmobl.com:8088/mms?" that was mentioned in the thread which link is above.
Open txt message app> Settings > Multimedia Messages (MMS) > Connection Settings
Change Name to : V-Mobile MMS
Change MMSC to: http://mmsc.vmobl.com:8088/mms?
I tested sending an mms to myself and to a friend and both worked receiving and sending as well.
Hopefully this help guys.
I made this change today and can now receive MMS! Not sure why the original settings were for T-Mobile. I still cant send MMS. Is there something that has to be done to get the send part working?
Thanks.
Hey guys. I've been away for a while. I will have a update soon. I'll try to update Google now. I'll see what I can do. And I figured out why you guys were having trouble with mms. I made a special version of the ROM for a friend on tmobile. I uploaded the wrong one for you guys. sorry about that. I wasn't having issues because my settings were correct. Sorry about that
Are the MMS settings above correct? No other values needed? I'm still having trouble sending MMS, but I can receive now.
Also not sure about the 4G? Is it supposed to work on this ROM? I have turned it on in locations where the stock ROM was able to connect and don't see any change in the notifications area that I'm on 4G, still says 3G. The toggle says 4G is on but I don't see any speed improvements either.
Thanks!
Everything works except mms. The mms fix someone posted will correct any issuesSo we are running the wrong ROM ?
any chance someone can post the rom on another site, i'm getting 5-13 hour download times for this rom (other sites its like a few minutes lol)
4g is working correctly. I would try a re download and re flash
I would assume stock is needed
When 4G is on will it say 4G in the notification area? Why doesn't 4G show up in the full settings list only on the Quick Settings?
Can anyone answer these questions for me?
There is none. This is a barebones ROM. You can add them by adding livewallpapers.Apk from another ROM
You can get them from just about any ROM. Just download mobsters ROM. Open the zip. In system>apps the file is in there. Just drag it into my ROM and then flash
Add livewallpapers.Apk. To the ROM before you flash. A lot of System apps have to be flashed with the ROM. Then add live wallpapers
