j1232
-I believe is to be able to save space; and if you want the full settings on your screen, you could easily add a Widget for that.
-4G Notification will display steady once you are connected to it, if not, it will appear on top as not connected and searching.
ummm not when wifi is on. .
also issue with syncing the browser and calendar . . . anyone else have this issue?
