it should work. but i saw that V12 dont have maps and i also cannot download it... strange. anyway i am using iGO for navigation![]()
hi every1
i upgrade my x8 from previous custom ROM 2.3.4 to this one v12
in factory version and rom 2.3.4 Google maps work fine
in this new version 12 Google maps CAN NOT LOCATE ME unable to find my location or something like that was the answer (when i am connected 2 my rooter)
also have problems with receiving config massage with setting 4 internet MMS ad all other stuff, The massage is sent to me from my provider but i do not receive it, while SMS from other contacts work fine
I need solution PLS help
i am running the gingerXperia v12 and i installed igo myway 8.4.2 and i am stuck at the eula screen, it goes past the border of the screen, and no matter what i try i can't get to the accept button to click it, who did you manage or what version did you install?
thanks![]()
Hi,
MMS problem is not new... majority of the custom roms do not have MMS working properly.
Is your GPS switched on? You need both Wifi and GPS to get Google Maps to work. My Navigation & Google Maps worked fine. You can download and install Google Maps & try again.
Hi,
This problem is not new.
Did you install from SD Card for did you install the app from Android Market?
I know a friend who is using Sygic Aura Drive and it works fine.
cheers
gabe
Hi, thx for this new v13 version of your very good rom, I have two questions, how can I oc and uv? I've read there are the modules and setcpu don't allow me to do it.
Have I to partition sd for apps2sd? What kind of ext?
Very good work, thx again.![]()
hello gabe... i jhave just installed v13 on my x8... it seems that everything works except that it doesnt recognize my SD card... I hade a same problem with all versions efter v6beta, which I have on my phone... any thoughts...
thx
Hey everyone, I recently got an Xperia X8 (E15i) and I am completely new to Android. I installed CWM recovery and used it to flash GingerXperia on my X8. However, when it's flashed I'm stuck with booting and GingerXperia doesn't continue loading. I have to restore my 2.1 Eclair backup then.
Now, the problem is NOT Baseband 15, because I already got Baseband 15.... what am I doing wrong?
Still not working. I tried flashing it and I got the same boot loop as before... I really, really want to use a more recent updated Android version on my X8...![]()
You mean "Factory reset (full wipe)" in xRecovery?
hi Gabe,
Why is my phone keep on vibrate when in call, and when my phone automatically change to ROAM which my service provider lack of coverage and automatically change to other service. Any solution for that?
How do you guys backup when flashing this software on, because before I flashed I used backup and restore then when it flashed I couldn't find the backup and restore no more in gingerxperia v13....
I'm looking to backup my contacts and saved txt messages
Thanks guys
