Hello again,
after severall tries, at first it won't find the X8, then using SE Compagnion it find the X8.
I've done the Flash using your tool. The "rooting" was not possible.
But after turning on the phone again, it's went in a loop. I disconnected also the battery, but it continues to loop.
What can I do now?
Thanks already for your fast help.
greatings,
Myk499
Hi,
reinstall the rom and use xRecovery...
<factory reset full wipe>
check SD Card folder
<Android><data> does not have purchases from old Market app
and make sure android.secure folder is empty
cheers
gabe
Hi,Hello,
please can you help me?
I installed V 17, but after reboot, my X 8 won't go furhter then the first display ( sony Ericson ). I've tried with de right "return" button, but nothing happens. Couldn't shutdown by pressing the top buttom also. I' ve also removed the battery, but no result. How can I resolve this problem.
Big thanks in advance.
Myk499;
I've just rooted and installed gingerxperia, so thanks to everyone who has contributed and made gingerxperia possible.
Question - I'd like to clear as much space as possible on my sd card. Is it ok to coompletely delete everything on the card now that gingerxperia is installed on my phone?
I have the backup of my previous rom saved on my computer.
I haven't installed any apps yet apart from 1 app.
Can I just wipe my sd card and then start installing my apps onto it?
Hello,
big thanks for helping me by this way.
My problems are luckely resolved.
I've noticed by trying to install the V 17, that it makes a remarke about a "kernel version", wich must be "06" (maybe about the baseband). Mine X8 baseband was ending at 15.
Sincere greatings,
Myk499
hi gabe! thanks for being so active in this forum...this really brings out the potential of our X8!Though there are some concerns about V17..
i upgraded my phone to v18 from v12, and realizing the crappy connection it has with the android market, i opted to degrade to v17..before degrading, i checked my baseband and it said "unknown" and degrade anyway (learned my lesson) so i ended up in a boot loop...
followed your instructions (thanks by the way) and ended up back with 2.1 with baseband ending with 015....this time i installed v17 (using xRecovery) still and i dont know why, but i ended up with a boot loop...did you personally tried V17? i was hoping that people will be warned about it because it would be just a waste of time fixing a boot loop again and again...
Is it possible to get Google Voice Search working?
I've installed it but every time i try to use it i get a message on screen saying; "The application voice search has stopped unexpectedly"
I'm very new to this rooting/rom stuff so maybe I've missed something obvious..for example is there a list somewhere of apps that should work with gingerxperia and apps that are known not to work with gingerxperia?
Hello,
since I've gotten also problems with installing the V 17 ( from same "Odex" like V 19 ?), I use V 14, in wich I'm very pleased to use.
I'll waite to upgrade untill I notice that here are no problems/bugs with the V 19.
Greatings,
Myk499
I did this to my w8 and Yes It helps but I encountered problems! My Battery Drains so fast! I already did Reboot>xRecovery>Advance>Battery Wipe But stil no changes , and sometimes My Applications randomize I mean they didn't stay at the same position gabeyong I Need your help!
