Anyone else getting terrible battery drain with V21b?
Hi
I just recently upgraded my X8 ROM to v21b and...I have some questions here I'd like to ask...
I really appreciate any help
- My battery drains twice as before! I had 2.1.1 Eclair on my handset before, and the battery usage is normal...but after I root and install the ROM, the battery usage is somewhat fastens up...I have tried clearing the battery stat like the first post told me, and I'm still looking forward its progress...or should I replace my battery?
- before, I installed Easy battery saver+task killer, with scheduling option enabled, but after I installed v21b, it seems like the app isn't working...the scheduling doesn't start, just doesn't feel like it works. should I replace it with another batt saver apps?
P.S: I just realized that v22 has been released. If I want to upgrade my v21b to v22, is it necessary to factory reset like when I installed v21b for the first time?
Hi,
So sorry to hear that your battery is draining too quickly.
I think you can go ahead and update to V22.
I always do a factory reset full wipe before I install any custom rom.
It just helps me to remember what went wrong with the install by eliminating doubt.
btw... I am still using v14... It works fine.
cheers
gabe
1. My basehand version is like this : xxxxx-xxxxxxxxx-xxxxx015 , is it ok?
2. If i change to 2.3.5 my contacts will be lost?
Thanks!
I install it and i get an error at com.sonyericsson.eventstream.calllogplugin. Whats this?
Hi gabeyong
i'v got some problem after installed GingerXperia v23
1. My facebook app won't sync with my contacts.
2. i got this error randomly - The application Call log extension (process com.sonyericsson.eventstream.calllogplugin)has stopped unexpectedly. Please try again. Everytime i need to force close and it annoyed me
3. Okay this is pretty dumb question... is multi touch aka pinch to zoom function in GingerXperia v23? Because i cannot multi touch...
Thx for reading my post and hope u can guide me a way out of this![]()
