hi,
version 2.3.7
"the application call log extension (process com.sonyericsson.eventstream.calllogplugin) has stopped unexpectedly"
whats issue??
thanks
I have been with gingerxperia from v8 and it has been great since I started upgrading.. thanks for the posts.
When will be V24 release?
Thanks
Why does 3g allways turn its self back on during the nigh with this my phone was set to use 2g networks only and has 3g disabled in power options but when i look at it during the morning 3g has been turned back on?
Hi guys can you please give me a new link for version 22.
Thanks.
Hi,
Here you go... GingerXperia v22
After you install check to see if Gallery is working... there were some reports that Gallery does not work for some phones.
cheers
gabe
The application Call log extension (process com.sonyerricsson.eventstream.callogplugin)
PS:I used the lastest version of GingerXperia.
ROM V23 is working fine ol d way but dere is only one problem dat i cant recieve messages in my phone now.....
plz fix dis ASAP...
