Hi,
make sure you wipe everything before you install GingerFast v2.
I would even wipe battery stats...
Factory reset (full wipe)
Wipe dalvik cache
Wipe system cache
cheers
gabe
Thanks gabe
cheers
Hi,
Wipe dalvik cache
Wipe system cache
cheers
gabe
Hi Gabe, any news about an ICS porting?
hi gabe.. it'me again
i'm using the gingerfast v2... i just wondering if you have any update for this rom cause i can,t paly the hd game ( nfs shift etc )in here .. or may be you can help
i'm realy apreciate it
Thanks gabe
Cheers
hi,
version 2.3.7
"the application call log extension (process com.sonyericsson.eventstream.calllogplugin) has stopped unexpectedly"
whats issue??
thanks
i delet the call log extension from root unistaller how i reset the app again in my sys and i have't the backup
Hi,
You don't wanna do that. Trust me I have deleted and re-copied different files in and out of my system/bin folder. It really isn't stable.
Best thing is to re-flash the ROM.
Backup your apps.
factory reset (full wipe)
wipe cache partition
wipe battery stats
re-install the ROM.
cheers
gabe
My Phone turns into a silent alone each period of time Are there settings do in the system to convert it to a silent halt
I am currently using gingerxperia v23 in my x8. its an amazing rom, but having following issues:
1. getting error while opening gmail and YouTube and they needs to be force closed.
2. music stops when music player is minimized.
3.frequently getting a "calllog.event" error, which was resolved by turning off the automatic orientation.
music issue was faced in v14 as well.
Gabe please suggest some solution to the problems.
Hi,
You can use power widget so that you can control your sound setting on the home screen.
cheers
gabe
i just upgraded my xperia x8 from 2.1 to gingerxperia v23, working pretty well, im a noobey and this was my first attempt, i had 2 bugs that i found, this call log message keeps popping up and also the theme doesnt work, no big problems really, i like gingerxperia. ps anyone worked out how to put flash player on it yet, that would be cool to have, any adive for these small bugs would be welcome thanks
and I need to solve this problem in the program every time Twitter needs to type the password and if this worked for a re-run is there a solution to this problem
