Root [ROM v3] 2.3.7 GingerXperia Revolution ROM for X8
i instal gingerxperia v23 befoer but then i try to download ginger dx but my phone dead i use seus and it work now i am trying to download gingerxperia v23 but it not work after i see se log the phone restart plez help
Hi,
I highly recommend you try v22 not v23.
cheers :)
gabe
Hello,
I installed your latest version of gingerXperia. I have such a question, where i can create wifi hotspot. Maybe is that x8 hardware too old for that? But anyway, if not maybe u can help me with answer how to make it work?
Hye Gabe..Sorry if i'm off topic..but I need your help..it's about rooting..I just recently purchase a tablet from my local store..and It's all going great..it runs on ICS 4.0.4..but now I want to root it..my tablet is Ipro i3s..Can you help me?please..I nowhere to ask and this is the only forum(other than XDA..but their method didn't work)that really answer my question..fast..please hep mr Gabe?
Hi,
I do not have a Ipro i3s Tablet so I would not know.
Did you try SuperOneClick? It might work.
cheers :)
gabe
Hi Gabeyong and Android Users!!
just asking, about rooting x8, does this also apply to xperia mini pro u20i? thanks in advance..
-West
Hi,
Updated 03/04/2012: GingerXperia REVOLUTION V3 based on Android 2.3.7 CM7.2
This is the latest incarnation of GingerXperia from XperiaFan 13.
GINGERXPERIA REVOLUTION for STOCK KERNEL
Features of GingerXperia Revolution:
BASED ON CM7.2 V11
(ALL FEATURES FROM MINICM7 2.1.9)
ICS ANIMATIONS
TRANSPARENT STATUS BAR
WALKMAN MOD
MSM TRANSPARENT
RADIO WITH TRANSPARENT BACKGROUND
GOOGLE PLAY STORE
BEATS AUDIO
ARC LAUNCHER
GALLERY MOTION
ROBOTO FONT LOCK SCREEN
LIBS ADRENO FROM FIREDROID 1.0
XPERIA KEYBOARD
HEADSET FIX FOR MINICM
SUPPORT FOR STOCK KERNEL
XPERIA DIALER
TIMESCAPE
ZIPALIGN
DOWNLOADS:
GingerXperia REVOLUTION V1
GingerXperia REVOLUTION V2
Install instructions are the same... described below.
GINGERXPERIA V23 for STOCK KERNEL
This is a new Gingerbread 2.3 port is based on MiniCM7-2.0.7 by nobodyAtall
This "Gingerbread" Android ROM 2.3.5 is fast and stable.
Features In GingerXperia
3 megapixel camera
Wired headset control (Answer / end calls, play / pause music ...)
WiFi
LED Nodification
Expand ***** 2 ZOMM
No error restart! (SD safe to delete)
Video Recording
FM Radio
Apps2SD native Froyo
Market works well
Camera button (with the previous release)
brightness
Online load
Headphone Jack
Audio Mixer
Video Playback
YouTube, with or without HQ
GSM/3G/HSPA/Data/SMS
sensors
sound
open GL/3D
SD card
vibration
GPS
Bluetooth
USB Storage
Mute button on the call
compass
What's New GingerXperia V23 - 22 Jan 2012
FIX VIDEO RECORDING
FIX BATTERY DRAIN
FIX SOUND RECORDER
ALLS APPS IN OTHER LANGUAGES
FIXED ICON STATUS BAR
NEW ONLINE CHARGING
NEW MUSIC(WITH NEW FEATURE FOR CHOOSE TRANSPARENCY IN WITGET)
TO FIX RING VOLUME GO TO: SETTINGS/SOUND/PHONE RINGTONE AND SELECT YOUR FAVORITE RINGTONE
DOWNLOADS
GingerXperiaV5
GingerXperiaV6B (Bugs Fixed)
GingerXperiaV7
GingerXperiaV8
GingerXperiaV9
GingerXperiaV10
GingerXperiaV11
GingerXperiaV12 - Bug Fixed Release
GingerXperiaV13
GingerXperiaV14
--[Break]-- Developer was banned from XDA Developer's Website
GingerXperiaV17
GingerXperiaV18
GingerXperiaV19
GingerXperiaV20
GingerXperiaV21
GingerXperiaV21b
GingerXperiaV22
GingerXperiaV23
DISCLAIMER: Please use the info below at your own risk with no warranty of any kind.
PREREQUISITES <-- IMPORTANT!!!
1) Make sure you have Rooted and xRecovery installed on your Xperia X8.
2) Make sure you have new baseband xxxxxxx15 - check <settings><About phone>
If you don't have baseband xxxx015 your phone will end up in a boot loop
3) SONY ERICSSON Stock Kernel
If not... see the my post below:
Root, Install & Use xRecovery on Xperia X8 <-- here
AND
Using FlashTool to Root and Update Baseband 015 for X8 <-- here
INSTALL METHOD:
A) BACKUP STOCK ANDROID ECLAIR 2.1
Step 1: Make a backup copy of your Android Eclair 2.1 using xRecovery
- check that your phone's SD Card has at least 650MB of free space
[SD card free space is to hold both your phone original backup ROM and the 2.3 ROM]
- shutdown your X8 and wait 5 seconds -> <reboot> your phone.
- when you see the words [Sony Ericsson] on the phone screen -> start pressing the back button on your phone multiple times and you will enter the xRecovery Menu.
- select <backup and restore><backup> from the menu
NOTE:
- This will create a backup file in your SD Card <SD/xRecovery/backup>
- After you have completed the backup using xRecovery, it will return to the menu screen.
- Now choose <reboot> - your X8 phone should restart
B) DOWNLOADING 2.3.3 ROM
Step 2: Download GingerXperia ROM
- <mount> your Xpedia X8 and copy this file <GingerXperiaV8.zip> into SD card
- <unmount> and shutdown your Xpedia X8
C) Custom install the 2.3.5 ROM
Step 3: Installing the 2.3.5 ROM on your Xpedia X8
- <boot> Xpedia X8
- <select><factory reset (full wipe)>
- scroll down and hit <install custom zip>
- select <GingerXperiaV8.zip> from your SD card & hit <yes>
- xRecovery will start to install the 2.3.5 ROM on your phone.
- when it is done, xRecovey will go back to the startup menu
- <click><reboot>
Now you can start using your phone :) - Isn't Gingerbread 2.3.5 great!!!
DON'T WANT TO USE THE 2.3.5 ROM ANYMORE?
Well it was fun visiting and touring the Gingerbread 2.3.5 ROM, now let's go back to Eclair 2.1.1
D) RESTORING THE Official Android Eclair 2.1.1 ROM
Step 4: Reinstalling your original Eclair 2.1.1 ROM
- <shutdown> wait 5 seconds <reboot> Xpedia X8
- scroll down and hit <backup/restore><restore>
- you should see your original 2.1 backup ROM
- <select> <2011-10-xx.xx.xx.xx.ROM><restore> [it should look something like 2011-05-06.21.01.23]
- xRecovery will start to install the original 2.1.1 ROM [the ROM you've backed up in Step 1] from your phone's SD Card.
- when it is done xRecovey will go back to the startup menu
- <click><reboot>
And you are back to where you have started - Xperia X8 Android Eclair 2.1.1
If you have decided to keep and use the Gingerbread 2.3.5 ROM... like I did :)
DO send a big THANK YOU to the developers @ XDA for their hard work building this custom 2.3.5 Gingerbread ROM
credits:
nobodyAtall for the original Custom ROM
modified by MIGUEL ANGEL SANCHEZ BRAVO
cheers :)
gabe
ADDENDUM:
UPDATES WARNING:
DO NOT update to the new BusyBox from Android Market after you have setup your Xperia X8 with the 2.3.3 ROM or you will BRICK your Xperia X8 phone.
If you have bricked your Xperia phone... follow this guide to recover to stock Eclair 2.1.1.A.0.6
[GUIDE] How to rescue our bricked phone by Graveir @ XDA <-- here
Do or Do not... There is no Try - Yoda
I've done that thing "full wipe" and I've restarted my phone and now I cant acess to xrecovery... What should I do?
thanks gabeyong! I'm using GingerXperia REVOLUTION V2 now. thanks for the others roms like GingerXperia V22 I used it and is very stable! I registered to thank you!
Hi,
I have 2 Xperia X8:
I am using GingerDX v022 on one and Gingerfast v2 on the other.
Both works well. I would recommend both for everyday use.
cheers :)
gabe
Gabe,
Happy new year to you.
As said earlier, I am still on GingerDXv17, Now, can you suggest which one to go for Gingerxperia Revolution v23 or to go with GingerDXv22.
Kindly also provide the links to download the GingerDXv22
Hi,
Can anyone provide me the GingerDXv22 download link and instructions to upgrade from v17 to v22
this is the xda page of gingerdx. the links to download all versions of gingerdx are in the 2nd post. the steps are mentioned very clearly.
if you are already using gingerdx, it is possible that you can install the new/desired version of gingerdx rom without losing any of your data (and most of your settings) so you dont need to do a wipe from cwm recovery. i have done this while upgrading from v28 to v29 and from v29 to v30 and no data was lost, but not sure if the same works if you jump more than one version, or go back to older versions. safe bet is to take backup from cwm recovery before you attempt this, and then install custom zip straight away.
also, gingerdx was started by doixanh and developed by him till v22, after which TeamFun is developing the newer versions and the latest is v30. thought i should mention it as you said you want to upgrade to v22.
cheers!
I have installed Gingerexperia v22 on my phone which was running Gingerdx v17 earlier.
Had lot of issues to get the gingerexperiav22 working as i bricked the phone and had to send it to sony service to get it back with stock rom.
post that i installed gingerexperia v22 , but it more or less is functioning like stock rom, except i could move the apps to SD Card.
I loved the GingerDX as it was much faster .
Now i have a question, Can i upgrade it to GingerxperiaV23 without losing any data and apps that i have downloaded now ?
Is there a latest version after Gingerxperia V23 ?
I also have the same problem, the phone has slowed down at times it just crawls and seems like crashing after installing the Gingerxperiav22, with Gingerdx v17 it was excellent.
not sure if V23 is any better, as per update from tamerelturky, looks like no good.
the only way i think is to go to GingerDX, for that we'll lose all the data and settings, that's the one i am hesitating to do, otherwise i would have switched over to GingerDx.
