tamerelturky
I have a message appear every time on the screen lock application (google services gaaps framework) What do I do in this letter Please note that I root unistaller composite program Please help severely
Hi my X8 automatically reboot after installing any of the versions of the ginger xperia. im facing this problem since 20 days and i have changed many versions. when i install stock rom then it will be ok but when i root my x8 and install ginger xperia then it will rebbot automatically in some time. plz help me out
Hi,
The best thing to do is to re-flash baseband.
cheers
gabe
Hi sir Gabe... I installed the V3, its great... but seems like i can't see some apps, like the market(google play), maps, facebook,? any suggestions sir?
same here, no google maps,places and wisepilot; but there is a google play, the prob is when i go to google play and search for google maps app, it cant find it; and when i try to download it via PC, it says not available for your device's country. but when i install the stock eclair 2.1 update 1, it has the built-in google map.
Hello, first of all thanks for the great ROM (GingerXperia REVOLUTION V3).
Tell me please, does this ROM GingerXperia REVOLUTION V3 works as well with the nAa kernel ?
especially this one : [KERNEL] nAa-ics-03 [26/5/12] Custom ICS kernel + CWM Recovery - xda-developers
And if it does work, do I have to reinstall the ROM if I flash this nAa kernel ?
If "no" for all above, same question about nAa11 kernel...
TNX
Hye There Gabe,I'm new to this Rom stuff..Anyway after I succesfully root my phone and installed busybox and also Xrecovery...I finally got to use the Rom called GingerXperia Revolution V3..I was happy..but I want to try out the GingerXperia Revolution v2 this time..So I have 3 question..
1-How Do I installed this Rom if I already Have another Custom rom? Do I have to return to the stock eclair 2.1.1 and installed it?
2-what is the list of changelog for V2?
3-A bit out of topic..if I wanna flash new rom..and don't wanna lose all my app and msg..what app should I used? does Titanium Backup..backup everything? and how does it work?
I would appreciate if you reply to my question immedieatly...Thanks In Advance..please reply quickly Gabe..
Mine too..also..have u notice that..it lags? I Install Gingerxperia revolution v3 it was working fast for a few days..until last night..it started to lag..and it continues..I have no option but to uninstalled it and luckily..I installed GingerXperia V10 and it's damn more faster than GX Revolution v3..thank you for a stable custom rom gabeyong, i have successfully installed the gingerxperia revolution v3. have you checked out the CALENDAR? when i open mine it starts with ( sat fri thu wed tue mon sun ). its a reverse of the normal which is supposed to be (sun mon tue wed thu fri sat); pls help![]()
Hi Again,Hi,
If you wanna try some other rom just do a factory wipe and cache wipe before you install the new custom rom.
Xperiafan has been ban from XDA website for a while now so unable to get the changelog.
When you flash a new custom rom everything is gone (including your apps) unless you can restore from a backup.
Hope that helps...
cheers
gabe
Hi, I installed the GingerXperia V23 but when I go to <setting> <wireless & network> <4G setting> the application crashes
hi gabeyong, as i surf the net, i noticed all the other x8 using custom roms have kernel serial numbers,. mine does not have any? i wonder what kernel can you suggest to me,
im using your v23 update.. cyanogenmod
Hi,
I am sorry to hear that your 3G/4G is not working.
I am currently using v22 with 3G working.
Maybe you want to try.
cheers
gabe
Thank you but the link to download V22 is broken.![]()
