excuse me sir gabeyong, can i ask why is that after I installed gingerxperiav23, my phone could not detect the SD card, I tried other versions of GX but still after I installed them it could not detect my SD.
Hi,
Assuming your SD card is functional (not dead)...
factory reset full wipe
Clear cache
Re-flash custom rom
format SD card using phone
cheers![]()
Dear Gabe,
It's been a very long time that i upgraded to GingerDX V017 and i am much happy with it ( meaning, i am able to install and use all the features available on the phone ) Only thing is it is sluggish at times and takes time to boot and while operating internet.
However, Thought i could ask your advise for an upgrade .
Which one you would recommend me to upgrade from GingerDX v017.
Also if may pls provide the appropriate thread links..
Hi Gabe,
I know i'm a bit off topic..but Can You and other members in this forum help me?
1-how to identify the bootloader number? is it on the battery when I open it? or is it under?
P.S-On the battery it shows 12W04
and under the battery is 12W07
So which one is it?
2-I need to know if my X8 can unlock bootloader.
Thanks in Advance! N i will appreciate your effort in answering my question and please,please reply quickly! i really need help..
Hi Gabe,
Please provide me the steps to upgrade sony x8, Android version 2.1 to version 2.3.7.
Thanks,
Pradeep
I upgraded from eclaire to your gingerxperia 2.3.7 ver 1. the first download it was because I was confused which one to download as there is like 23 of them, so I chose the 1st to be on the safe side ,Im a noob lol. So far I am loving it, it defo goes the same speed as the old eclair if not faster. Found some tiny issues -theme chooser has only 1 theme and nothing I can do,,-the calendar is kinda messed up. Would you recommend to download v23 and wipe all and flash the rom,or should I keep my current version also is there anyway to zave my contacts and app perhaps. Thank you
HELP! I installed GingerXperia Revolution 3 in my Xperia x8 and did everything fine,(installed xRecovery,baseband,rooted my phone) but when somebody calls me it says that i am busy,i reboot it it still said that i switches SIM cards in case my SIM is broken but it still said the same think ,please respond quick,
Tagiadin John
