The Dev says you need to downgrade to Busybox version 1.18.2 or you might get errors that don't need to be errors. Go to the Devs site [Script][U9 Beta 6.1] V6 SuperCharger! The ONLY Android MEMORY FIXER! 3G & KAK! - xda-developers
This has all the info you need and more. Go to the Market and Find a Busybox installer that will let you downgrade (I can't remember but I think its the one by JRummy16)
With that said, I'm going to see my new score and compare with my old ones that I have posted not to long ago.
Edit-
Wow my score actually dropped about 200-300 points. I wonder why..
Quadrant score was 1200-1300 a couple builds ago, but now with this build + supercharger, my score is 900..
Is it possible to keep wifi connected even when the screen is off?
I've looked through all the data and wireless settings and don't see the option like in stock.
Where is this option?chaange wifi sleep policy to 'Never"
while your in wifi settings, press the menu key and then select advanceWhere is this option?
Here is a flashable kernel version 3.1F(F for Flashed kernel), that will update your current IHO ROM to latest kernel.As I have mentioned in the post before I'm a huge kernel junky when it comes to flashing. Would love to see a flashable form of the kernel so I don't have to go in and flash the whole rom all over again. Any ideas where/when this is to be available.
Many thanks to you Jerry and the others with their hands in IHO.![]()
What exactly is a "Kernel"? and why would I want to flash it?Here is a flashable kernel version 3.1F(F for Flashed kernel), that will update your current IHO ROM to latest kernel.
Just reboot into recovery and flash this kernel: BobZ-VM670-Kernel-Update-092311.zip
Don't clean/wipe anything...just flash the kernel update and reboot.
Enjoy,
Bob
Even with the decreased scores, performance does seem way better and a lot smoother, Soo I'm not complaining. Lol
Kernel (computing) - Wikipedia, the free encyclopediaWhat exactly is a "Kernel"? and why would I want to flash it?
