JerryScript
Android Expert
http://androidforums.com/3224248-post869.htmlHey what are the benefits to using the 9/19 build against the 8/30 build?
Try flashing the newest Gapps: http://goo-inside.me/gapps/gapps-gb-20110828-signed.zipHi, I have been using this ROM for a while and love it. I've got a problem though - when I update from 0825 to 0919, I can not sync with my Google account (the previous settings from 0825 are not saved, and when I go to Settings->Accounts & Sync -> add account, there is no option for a Google account). I am also missing the Weather & News widget.
thanks
All "V" are not created equal. Has to do with the manufacturing of the tiny processor.I run at 825 start on boot and everything on my phone runs better. When flashing a new rom its the first thing I set.
EDIT: I didn't look below his post. Time to get some shut eye timeHey what are the benefits to using the 9/19 build against the 8/30 build?
If some member is having force closures and process system errors it can only be two things 1. Didn't wipe and format everything they should have.
2. CPU speed is to high for there "V"
If I jump up to the same CPU speed you can on the initial boot up of the ROM/update without a couple of reboots on it then my system will freeze,randomly reboot,or just act plum goofy.
I think nightstalkr has a processor in the similar state that mine is in.
Super user updated in the market today.
. Great Job overalland there is a pro version now? whats the diffrence?
Apparently you can back up apps with the pro version, and there's some other stuff, bit I didn't really read the notice that popped up when I updated. It looks cooler though I think
I think I've found the safest and highest I can leave it at without experiencing ANY auto-reboots is 768 performance. I think it gets the job done even with gaming ^_^
Also, I was reading some reviews on the new update for Superuser. Some people are having troubles after the update? Has anyone updated their Superuser and experienced any problems?
Run it and it will tell you to update make sure you do.
Having an issue with ringtones. I pulled my uSD to do some testing with Rom Manager and when I put my regular card back into the phone none of my ring tones work. I have them all on /mnt/sdcard/media/audio and then /ringtones /alarm /notifications.
I can browse to these folders and see the files and play them. But I can't select them as ring tones. Hoping there is an easy fix for this.
