exProphecy
Use 8
and install script manager from the market.
move the scripts to your SD card (not in any folders)
Run script manager
locate and open the script
Make sure "run as root" is checked and run at boot is NOT checked
and run
chose a number 1-3 for scroll speed (tap anywhere on the screen to bring up touch pad)
choose you option (recommended "9")
reboot.
repeat, (recommended "12")
press home key and your set.
Wait I was reading another tutorial saying to install BusyBox. Do I need to do that ?
EDIT: Nevermind, I just did it without having to deal with BusyBox. So.. after I enter 9, I just kill the script then close then reboot? Then run the script again and enter 12 then home button then I'm done?
