Is the internal app moved as good as App2SD?
I'm getting an error with 3G. Anytime I open a browser, it directs me to the VMUSA site, and prompts me to login, which I cannot do as I get the following error:
Data Connectivity Problem: A secure connection could not be established.
No idea of this is the ROM, the carrier, or me. Works fine on wifi, though...calls/text also unaffected.
thanks but that didn't help.
wifi drops a lot too on for some reason which I never had a problem with on aosp's. (but aosp had bluetooth and GPS issues) so I'm trying some of the other IHO builds (on BobZ's right now)
I hope in time some of the bugs in Backside rom get worked out. but it did occur to me that they could be from Blarf or IHO itself. or some obscure configuration I'm using.
You need to do all these things(this must be done when installing a new ROM or restoring a backup, or wiping and reflashing a fresh ROM)why isnt this thread stickied? and how do i reflash the rom i just want everything fresh to like the point i have to reflash rom and gapps
New build is up, removed bootloader from the reboot menu, switch to Blarf's v2 kernel to work with newer screens
You will probably need to flash gapps, ymmv, only adds 1 1/2 minutes to the entire process.![]()
I just wanted to let people know about buying extended batteries if you guys haven't already looked into it. I believe stock battery is 1500mAh? right? You can find some really cheap ones on eBay that are about 2000mAh-3000mAh. The one I bought from China is 3600mAh which is pretty massive! xD It's well worth it though! Lasts about 1 and 1/2 to 2 days on regular use (remember to use JuiceDefender!) But JUST today... I looked on eBay and saw 3900MAH!! oh em gee.... >_< seems a bit ridiculous.. anyways, there have been posts over here: [Review][WIP] 3600mAh Extended Battery with Backplate - Android Forums and.. over here: 3000 mAh battery - Android Forums Just a heads up for you folks who didn't know ^_^ (Buy 'em from eBay much cheaper! Got my 3600mAh for about $12 bucks free shipping! Only problem is, it took like 2 weeks)
The only issue with those is allot don't have capacitators and will over heat till they explode also some will say there so large when there not. They hack the internal chip to output that reading. There ok to use just be cautious about how hot your phone is.
New buid up, lots of changes over the weekend, should only need to wipe cache/dalvik
-- Changed wifi supplicant scan interval to 60 to save battery, if it gives you issues, you can change in in the build.prop file
-- Changed to BobZhome's kernel, lots of tweaks, all screen should work now
-- Edited build.prop to reflect changes in OV2.2.2 and OS-ZVH versions
-- Added supercharger settings and other tweaks to build.prop
-- Center clock in status bar, thanks to Drew
-- Removed trackball settings, never could find it on my phone
-- Added extra camera button settings
-- Added Build ID to Device info menu, with a thanks to Blarf (find it)
I recomend flashing gapps after flashing my builds, it's usually necessary due to my build/sign process.
Do not use previous Green Machine Theme's with this build, I'll have a new theme version up by the end of the day, so long as UOT Kitchen is back up.
BACKside-IHO-VM670-09192011-signed.zip
