What is your battery off charge time,and the temp at cold idle and after using in the heat of the day.Here is my phone at 864MHz with smartass:
?? krazy!can you explain how the smartass setting governs the cpu in comparison to the other settings?
Are you on smartass governor regularly or always on performance? Oh and I tried 825 max on performance then ran Quadrant Advanced.. crashed in the middle of testing >_< 806 max performance ran through testing at least.. So I'm assuming that's my phone's limit =[ Have you tried running quadrant while on your 825 max performance setting? TRY IT TRY IT xD and share your score! It shall be spectacular I would imagine haha![]()
I've got a few ideas for the next build.. some customization features for the desk clock/dock clock (whatever its called when you click the clock). I mean its pretty much the only thing that's lacking customizing features. If its not possible, or your not able to, that's fine. Its just a suggestion.
(By few I mean just that one... seeing that it might bring up more ideas)
Nope sent one just fine only hours ago.
When I go to the facebook app, however, and hit the menu key and go to settings, the phone freezes. Anyone else get this?
I've been using link for quite a while now it was the original reason I rooted, I have never been able to get it to work without doing a full format and restore the apps through titanium. The issue your explaining always happens no matter the rom. So every update or rom change you need to format and restore you're apps with titanium. Just restore link first then run link mount the partition and reboot then restore the rest of your apps.
Try power off/pull battery/hold power button for 30sec./Reinstall battery/power on.
Just letting you all know that there is a fix for the no audio when recording video bug. Deleting cameraclick.ogg and videoclick.ogg from system/media/audio/ui seems to do the trick. Tested, made phone calls, audio still worked on video. Strange.
I don't know what you format but I wound up formatting my SD card, repartitioning and then copying my SD card backup from my PC back to the card (I like to keep a copy of the SD card on PC for just such occasions). This seemed to do the trick for me. I reloaded all apps from TB with no issues.
JerryScript: you are probably right about how many apps are actually not used. I have a bunch of large games on my phone and about the only things I use are Wordsmith, EnjoySudoku, and a few others.
I switched to the recomended recovery for the IHO builds(asopCWMod v3.0.2.4) and I have not been experiencing the problems that I used to. asopCWMod might be doing a better job of wiping data(residual data will corrupt a new ROM or an update to an existing ROM,and cause the system to act all kinds of FUNKY)thanks but that didn't help.
wifi drops a lot too on for some reason which I never had a problem with on aosp's. (but aosp had bluetooth and GPS issues) so I'm trying some of the other IHO builds (on BobZ's right now)
I hope in time some of the bugs in Backside rom get worked out. but it did occur to me that they could be from Blarf or IHO itself. or some obscure configuration I'm using.
They just rolled out the s gb update. Will we be possibly seeing a new kernel in the new future. I also started getting the sound recording issues used the delete fix but I actually like having the click sound if possible to fix that it would much appreciated.
You problems are not with this ROM as there are so many more members that are not experiencing the problems that you are. You problems stem from the recovery not wiping correctly. I tried Blarfs recovery( He even mentioned it works with some "V"s but not for others) but it didn't work on my "V".
I have not been having any problem with Bluetooth or GPS while using the asopCWMod recovery. You might have had problems with a previous build that had Bluetooth and GPS bugs,but all those bugs have been engineered out now.
I'm not really sure,but, you could google it and go to the dev's site to see the change log(those things that were fixed or improved).just an update here, I actually had more problems with BobZhome's ROM than BACKside ROM. (bluetooth pairing wasn't working, and I got the same screen turning back on issues) I'll continue to troubleshoot the screen issue, it may be an app I'm running.
I've been using asop's ClockworkMod Recovery 3.2.0.0 since june, whats the difference between v3.2.0.0 and v3.0.2.4?
It is always better to get the newest version of something as bugs get engineered out with each new version.
