JerryScript
Android Expert
Have you tried uninstalling the FaceBook app, and then reinstalling it? I don't have a FB account, or I would test it myself (never wanted, and never will have one).
You "used" it? Used what?
My specific issue is that when you go to Facebook>Menu Button>Settings, the screen freezes, facebook crashes.
Also , now I'm not receiving email notifications :/
Wow, what kind of car do you have that goes faster than a radio wave?
Never heard of that issue. Have you tried reinstalling gapps since maps+navigation is built into them?
That may be your issue, maps is a system app, and should never be backed up or restored.
There's an option to create an update.zip in titanium backup (go to your app list in TB press the menu button, press more, scroll down, press create update.zip) and from what I understand it packs all of your apps into it, I'll try out my theory. And if it works, cool, if not, oh well.
I just went thru all the links using my PC and they all sent me to where they should. EDIT: Just went thru all the links using my phone and all links are good.ive ran into a little problem.
ive downloaded the 8/31 build, and did a clean install, and rebooted, but now every time i turn on my phone, it boots into fast boot, and i cannot access recovery via holding power, vol -, and home.
is there any way to fix this?
Fixed, used the fastbootroot method to fix it, returned to stock, going to try re-flashing the rom and blarfs recovery
it happened again while trying to flash the 8/31 rom, going to revert back to stock, and then flash 8/25
i found out the problem, the build 8/31 link on the first page, downloaded the greenmachine theme for build 8/31 (now i get a time out error when i click the link)
i realized this when i looked at the file name in recovery, (greenmachinethe-08312011.zip) but i clicked on the link for the rom, not the theme, so please fix links, and im guessing that im the only one that ran into this problem, seeing how everybody else could install build 8/31 with little to no problems.
the mediafire links seem to not be working.
Try power off/pull battery/hold power button for 30sec./Reinstall battery/power on.Anyone know if these new screens are better than the old ones? Can't seem to find anything on google comparing them
And anyone else having issues with their screen turning back on after turning it off? Happens a lot with the lock screen disabled via power control widget, and when it does the screen doesnt idle time out like its supposed to. Doesn't seem to be related to any foreground or background apps either.
Went to the thread in the link,but only the ROM is mentioned and has a download link. yogi4 mentioned a link to the IHO thread that has a recovery that bigsupersquid put together that should work with the ROM that EmuZombie put together for the "V"'s with the "S" screens. Here's the link [ROM+Kernel] Inferior Human Organs unofficial CM7.1 - Page 158 - Android Forums go to post 1578 on page 158 you will see it in bigsupersquid's postHere's the info and correct ROM/Recovery version you need if you have one of the newer screens:
xda-developers - View Single Post - [ROM+Kernel] Inferior Human Organs unofficial CM7.1
