tying to install build 11/09 but it keeps on freezing at the boot animation ... cleared cach and davick cach but keeps on freezing .. any ideas .. ???
Are you coming from a previous cm7 build?
Sounds like you might have a corrupt download. I would try re-downloading the ROM, then try reflashing it.tying to install build 11/09 but it keeps on freezing at the boot animation ... cleared cach and davick cach but keeps on freezing .. any ideas .. ???
While attempting to try out other ROMs today, I couldn't get my Link2SD to work properly. I eventually gave up and restored my last ROM from clockwork recovery and now I am all recovered. Except that I still can't get Link2SD to work and all of my apps are not showing up. I also can't install them from my computer because it says they are already installed on my phone. I tried to partition the card again and the same message shows up "Mount script error. Mount script cannot be created. mount:mounting/dev/block/vold/179:2 on /data/sdext2 failed: I/O error." Any one else having this problem and if so how is it fixed?
Google music updated today
Go into recovery,backup and recover, advanced recover, choose the same recovery u just used, then choose sd-ext. That should recover your links. Worked for me at least.
I've noticed a few bugs lately
1) when listening to.music and get a text sometimes it will.suddenly.get quiet until another text is received.
2)while in a call.you.must go volume up to play correct shown level.
3) I've been getting a worse battery.life (no new apps installed besides stock,to confirm)
4) my phone will randomly reboot
5) makret refuses to download sometimes
Thoes are.the only.bugs I have noticed though
and some awesome features would be
1) music app would be awesome if there were some.customization features
2) if the bottom lights would light up as an led would for notification
3) if the status bar could be changed colors
4) the bootloader option was nice in the reboot menu
5) a push notification for backside updates
6) the.radio to work lol
just some sugestionsI was gonna try it but.I don't have time.till Thanksgiving
6) Why get FM radio when you have unlimited internet on VM for Pandora?
Because Pandora is horrible? You can only dislike songs, not bands, genres or albums.6) Why get FM radio when you have unlimited internet on VM for Pandora?
Try plugging your phone in, going usb storage, go to your your usb, then android, data, delete com.google.android.music and com.android.music. then turn off usb storage and try to install and run the app.
