AndyOpie150
<strong> <a href="http://androidforums.com/optimus
If you use "connection tracker" in conjunction with watchdog you will know which apps are hoging power and sneaking on the internetGive Watchdog a try. It sits in the background and will alert you if any apps misbehave (eat too much CPU), then it will give you the option to force close the misbehaving app.
