Root [ROM][WIP]CM10.0.0.l0-BobZ
About this slow in my area. But as opposed to 4G, I wouldn't know. Maybe I should have checked before flashing, but it isn't too bad.
Now, I've noticed that, after some uptime, the status bar just freezes up. It won't update or anything, and I can't even pull down the notification shade. It's not really deal breaking for me, I just thought it might be worth mentioning.
Thank you, i tried out the rom and it looks amazing but not having 4g is a killer. I will stay on top of this thread for any updates:D
Yes the Rom is great bit here in Sacramento I get about 6-7mbs in 4g in 3g get less than 1. Now in the future once pg and Bob have done all they can possibly do I might use this but for now I'll wait and see before flashing again to see if 4g can get working.
similar speeds as me i tried downloading es file explorer it was taking over 5 mins i cancelled it and did it with wifi
Wasn't there a thread explaining how to somehow boost the 3G speed?
I flashed from F and i saw that on msm-dvcs it was almost always at 1.5ghz and the phone got hot really fast. The purple camcorder also happened to me. I booted into safe mode to see if it was an app causing the 1.5ghz but it wasn't and now after about a minute it reboots and then reboots again after about a minute. Ondemand is worse 1.5 non-stop. Rootdim made the lock screen black and i have to blindly go to the app and change the brightness for it to go back to normal.
Go on RootDim, hit the menu button, hit the options menu, and check this option. Hopefully I'm understanding your brightness problem enough to give you the proper advice.
I tried that last time but it didn't work. I just did a factory reset and restoring my apps. Something must have messed up my phone to cause the 1 minute restarts. I'll try again once it finishes restoring. EDIT: It didn't fix it the screen is still completely off when i press the power button. I can interact but the screen is completely off.
I don't trust those dimming apps. The first one I tried a while back on stock "screen filter" made my screen unresponsive for 2 hours. rootDim makes the screen black sometimes. The only one I have found that doesn't mess things up is "night mode"
I tried this after seeing the first post about 1080p not working.
It records without the purple problem but it doesn't save the 1080p video.
Yea i've tested it alrdy..it only saves the one under it wich is 720...doesnt that camera's have like 8mp or something like that? Could be why its not saving at 1080p
Edit: tried the Miui camera..and that doesnt even have 1080p :p
I copied libcamera_client.so, libcameraservice.so, and liboemcamera.so over from bob's first build.
Nothing changed. v.v
Could someone help with this issue? My phone seems to be running at 1.5ghz non stop on both ONDEMAND and MSM-DCVS. Could this be from an app or a bug?
Same thing here.
UPDATE: Apparently some kind of 'debuggerd' process was running and chewing up 20% of my cpu forcing it to stay at 1512. Weird... does anyone have any info in it? I'll go check if i can found out some more about it since i ended the process the moment i saw it.
Any one with script skills check this out it might fix call echo in cm10 https://github.com/spanner3003/p1000-kernel-cm9/blob/master/scripts/Makefile.build
That can't help us...we can't play with the ram-disk or kernel because of the locked bootloader.
The echo issue is a high priority...the wifey has been complaining about it. I haven't looked into the issue yet, but I don't believe it is CM problem...because the echoing is not happening on our end. I have an idea as to what is cause the problem, but it may not be fixable :o
On a good note, I have LTE working on my phone now...but I still need to do some more work on it. Hopefully, I'll be able to get a release out this weekend :D
Could you do a quick check to see if there is some app or service that crashes/hangs because my phone wont go out of 1512 mhz so something must be demanding that cpu power. A system data wipe plus a reflash fixes it but it comes back if you reboot it normally after. Coming from F, other than that everything is fine and good.
Possibly functioning LTE and learning that I don't have to come in to work on my birthday? Today just gets better and better. I can't wait.
