Root [ROM][WIP]CM10.0.0.l0-BobZ
Anyways back on subject. . .
couple of questions. Did anyone experience the frozen status bar on BobZ first build? I did but not once on his new build. And should the new build be flashed from F since BobZ new build installs the boot image and kernel from F?
Oh and for the spirit owners in here, metro chick said the spirit is the motions replacement and it isnt suppose to be locked.
I am almost 97.6537% sure the the spirit is locked up. I was going to get one but the metro guy said it was locked jus like the motion :'(
Then i did some research and it seemed that it was, and then did some more research and it seemed that the motion has made a lot more progress then the spirit for my taste
Please tell me everyone else speeds increased dramaticaly? Went from 91kb to like 200+ on 3g alone..speeds are random though so idk im thinking that was luck!?
When i try to install cmw recovery it just reboots phone any help?
When getting rom it wont download is keeps saying this and when i click the link just refreshes page
Just tried it everything seems to work now except 4g instead i get 1x i cant seem to get 4g working for me i flashed from deodexed version D
Bobz thanks so much so happy 4g is working you made my day you can have my first born lol thanks so much for all your hard work words can not explain how happy i am
noob question here: can i go back afterwards and do advanced restore and restore system and data and get back my apps or will that nullify what i just flashed. ok nevermind. just don't format /data if your upgrading from previous bob rom. had a noob moment there srry.
GOT IT YAHOO! Thanks guys love it! ROM is sick! With the data saying 1x is that mean 4g? Or will it say 4g
Great job Bobz! I think I'll wait until the call echo is fixed to flash though (the gf got irritated with it when we were on the phone).
Something I noticed: when pressing the power button the screen doesn't go completely off it just turns black
Holy shit brightness, keys, AND LTE working....Thank You! Installed yesterday and now this, thanks Bob you're the best
Wahhhhooooo yeah, thanks bobz. I'm liking how fast your pushing these out sir, thank you for your work and dedication. Now us people in the forum need to fix this damn echo!!!
http://forum.xda-developers.com/showthread.php?t=1934495 im using this app. screen standby. for now to turn off backlight. but you have to set it up in settings to turn it back on. mine is set to turn on by volume up. i'm using one two dim mode and volume up turn on volume down turn off. i use one two dim mode because it has option to persist after sleep and option to start at boot which keeps the app on in background allowing you to use it when needed. and in settings/media buttons i set to control on and off with volume rockers. then i can push power button to lock screen then volume down to turn off backlight. and push power button again and volume up to turn screen on again.
