How do we screenshot?
. Amazing worksome bugs I noticed while had it installed
1. No data cause airplane mode was always on after reboot
2. Wallpaper like mentioned above
3. after unlocking phone phone got stuck with the vibration on and had to pull the battery
4.Android market blury
5. real bad echo when making a call
6. backlight not shutting off
7.call vol really low
Other than those this is awesome thanks for all the hard work put in to it!
I also flashed from f and everything works perfect except for the backlight, which won't turn off after lock. Great ROM
Something wrong with AF, it won't let me edit my OP. So new ROM can be found here
BobZhome, push you latest changes please.![]()
http://forum.xda-developers.com/showthread.php?t=1934495 im using this app. screen standby. for now to turn off backlight. but you have to set it up in settings to turn it back on. mine is set to turn on by volume up. i'm using one two dim mode and volume up turn on volume down turn off. i use one two dim mode because it has option to persist after sleep and option to start at boot which keeps the app on in background allowing you to use it when needed. and in settings/media buttons i set to control on and off with volume rockers. then i can push power button to lock screen then volume down to turn off backlight. and push power button again and volume up to turn screen on again.
You don't need to press up (at least more me) the power button turns the backlight back on automatically. I just have to press down, that's all.
Hey could you tell me how to set it up, I'm having trouble making volume down turn off the screen
If you flashed the latest build 1x is 4G but the system doesnt reads it but it is 4Glte already if speeds are slow is your area
