Root [ROM][WIP]CM10.0.0.l0-BobZ
Right at the beginning, I get an error saying com.android.phone has stopped.
EDIT: When I make a call, I can't hear anything either.
EDIT2: Camera wants me to insert an SD card when I already have one inserted.
EDIT3: Screen randomly shuts off
EDIT4: "Android process com.(something).media has stopped" out of nowhere
EDIT5: Data isn't working even when data is switched to 3G.
EDIT6: Mounting it on my computer won't work with either MTP or PTP
That's exactly what happened to me. I ended up going back to stock again :p
Firmware: C
Mods: none
Issues: Camera upon reboot takes the first picture fine but the rest will be black images. It wont work again until another reboot and then it will only take one photo again.
Sorry I have no logcat but i'm sure you can reproduce this again, just take like 3 pictures and swipe left to open the gallery and you'll see what I mean.
well we can rule out flashing the baseband from the lg nitro hd as a possible ril fix, I tried it and it gets to the lg logo lens flare animation on boot, freezes about 3/4 of the way through it and sits there with the screen flashing on and off at the same spot in the animation, not a bootloop because the animation doesn't restart, it just doesn't complete either.
Firmware: C
Mods: none
Ya, gallery is a little funky...the pictures are not really black. If you exit out of camera and go into gallery you will see the pictures correctly.
This issue is on the list :o
Replaced all lib files in Bob's build with PG's and added all extra files that were in xbin of PG's build.
Brightness is working, hard key lights are working. I have not experienced any reboots, force closes, or freezes. Facebook installs now without rebooting
Flashed from: E
Mods: none
Edit:
Issues: When pressing the power off button to lock the screen and then quickly pressing it again to turn it on results in a completely black screen. It like breaks the display but you still hear everything you do on the device. Until you reboot(pull out battery)
Issues: Usb connectivity doesn't work when connecting to computer doesn't even charge when connected to the computer. Charges fine on normal wall charger.
Flashed from: E
Mods: none
Edit:
the black screen sounds like the rootdim issue i saw. theres an option in it to fix it, but i indeded up uninstalling it
When I took pictures with the stock camera and tried to view them on my computer the images were 0kb and it said that the images could not be displayed and in the gallery they were black but i've found that using an alternative camera app such as the motorolla cam or the miui cam fixes this. Btw thanks again for helping us get a pretty stable cm10 going for the motion! Btw when i try to use GPS it doesn't work, i saw a post somewhere where someone said it did so i'd just like to point out that it didn't for for me. Btw the app I was trying to use was Maps.
Flashed from: E
Mods: none
Edit:
Press the power button several times, screen will come back on. I had this issue in BobZ private release ;)
Flashed from: E
Mods: none
Edit:
All Issues fixed.
Take bob's build and use it as base.
Go into bob's build. Go to the lib folder.. and Copy and paste "hw" folder to your desktop
Delete the entire lib folder and replace it with PG's
Go into the lib folder and open hw
replace all files with the original's (The ones you copy and pasted to your desktop) After you replace all files you should still have lights.msm8960.so. Keep it.
Rename cm-10.0.0.l0.BobZhome.04122013.zip to something easy. I named mines "Merge".
Open it with 7zip go to system and delete the lib folder and replace it with the modified lib folder you just made.
Everything works perfectly. No more force closes, no more random reboots or reboots when installing apps :D
Now we just need 4g.
Thanks a lot PG and Bob <3
All Issues fixed.
You should upload the new file? (:
All Issues fixed.
I can confirm this does fix brightness and the back lights , but I am still experiencing reboots after installing some apps :confused:
All Issues fixed.
Go into bob's build. Go to the lib folder.. and Copy and paste &quot;hw&quot; folder to your desktop
Rename cm-10.0.0.l0.BobZhome.04122013.zip to something easy. I named mines &quot;Merge&quot;.
Thanks a lot PG and Bob &lt;3
Would this make the calls louder and no echo?
All Issues fixed.
Just tried this and it seemed to work but the only thing i noticed it when you lock the phone it doesnt go off it stay on a black screen and when u lock it again it goes off also its hard to make it come back on
