Thanks, I'm downloading it right nowand what's that bug??
Sound glitches... try playing candy crush saga?
Is there any way that goo manager could be of help for this phone?
Ok, so I'm back on CM cause I can't stand the status bar and lock screen on stock. I flashed BobZ 5-21 and am happy with call volume, data stays connected after reboot, and even GPS works pretty decent, just a little slow]. Now a couple of things that I wish I could get working are
1) Bluetooth audio - I listen to Pandora and Tune-in on my phone and would like listen to it in my truck. It connects but it doesn't play thru the radio instead it plays on the phone. I can still control it from the radio.
On PG's build BT does work. Maybe I'll back up this one and flash PG's, but I think I had low call volume on that one last time I used it.
2) Media connection to computer. It does not connect to the computer. What is missing is the MTP driver. It connects to DFS and QPST perfectly, just not as a media storage. When I'm on stock the drivers work fine.
Any help with these?
I had the same problem with USB storage, it works. You just need to know how to use it. First of all go to your setting then go down till you see storage and then press the menu button and it will say "USB computer connection" just press that and check mass storage and you're doneconnect it to your PC and check if it works
So is the call volume / echo, and GPS working properly now? How's the battery life?
hows the progress with this
I tried both PlayfulGod's 5/17 and BobZ's 5/21 builds. Volume and echo seemed fine, whereas GPS did not work at all. I tried several fixes mentioned in this thread to no avail. I highly recommend anyone who depends on GPS to stay away from CM for now - a few people have it working, and a few people are able to fix it, but the overall consensus is that there's a major irreparable problem with the GPS for a heck of a lot of people. You can of course go back to stock but it'll take a while and you have to learn your way around the unbrick guide, morningcall errors, et cetera.
Battery life seemed good for the short time I had it, though.
Update: My Motion died and I could not wait 5 days for Metro to get me a new one...so I bought an L9(same price as Motion). Then Metro would not replace my phone since I no longer had service on it...so I contacted LG and they finally gave me an RMA# the other day. I have to ship it out to them now and I'm not sure when I'll get it back at this point.
How do you like the L9? Did you put out on Metro's BYOD?
What?
MetroPCS is selling the L9s.
Therefore, he bought it from Metro and it's not a BYOD device. He's a Patriot fan, so I guess he lives around Boston
He has the one branded MetroPCS.
Thanks, I know that Metro sells it. I guess I was thinking what of my sister-in-law did with her L9. She bought it from Bestbuy, and put it on Simple Mobile. So, when bobz said he got one, that's the first thing that went thru my mind.
I'm on 5/21 or 12 - whichever and when I use skype or oovoo and I answer a call, the screen just blacks out and comes back on like a reboot. Any idea how to fix?
There might be a fix I have front facing camera recording On the paranoid port. Even had Google hangout up but lost sound.
