alfick3
Android Expert
Which one did you flash? the MMS fixed one or BobZhome's original?
I flashed bobz original (well, his newest build that is).
Mms seems to be working for me out of the box with the latest build
On his original? seems like he finally got it working xD
Yup, original. Apn list is blank but pictures still go through.
Bob, do you still need the logcat log? also which is your prefered method of delivery? Do you want it from boot to finish, or just the intent area?
I have logs already, but i was up pretty late, so I'm gonna redo them just to try to have them be as short as possible.
hey bob... something curious i think you might want to check out... I just tried a factory reset after the MMS fix, and it seems the changes stuck... so I went into the metroff zip and noticed in mpcs.sh the only real change made that would survive a factory reset.
ro.cdma.home.operator.numeric = 310027
So I did a small test... I made that change in the 32412rom and guess what... the changes stuck! I did not include the MMS.apk.
I'm gonna redo this to make sure I'm not just tripping...
edit: just to be clear, I wiped all the partitions on my phone before seeing if this would work
Man I wish I had service to try it out.. :/If someone wants to try this "fix" here ya go
CM7.2RC1-MS690-BZh-032412-mms.zip
md5sum:c78959769f58678f04b96c7d729a7f85
here is the log cat
I pulled just the intended from before the fix
then all i did was go back into recovery, manual changed the build.prop and deleted telephony.db rebooted and it worked
so the rest of the file is the entire log, i marked off the log alittle, you should notice them
http://dl.dropbox.com/u/11452763/adb-logcat-MMS.txt
Every time I download an application from Market I get an error saying " Package file is invalid." Then I can't download the app. Do you know how to fix this?
