BobZhome
i have to ask when are yu bringing use cm9
I'll have an alpha build soon, still working on the kernel.
And MMS?
No I didn't mean with ICS lol... I just meant will he release a new build with your MMS fix implemented into it... I put it together .....It was Primed's idea though.With ics, ya should jyst bw happy it boots n touchscreen etc works
Reppard fixed MMS out of box long ago. I'm sure if Bob was going to fix it he would have by now.
Then why didn't he when I did?
Bob was n is still trying to get mms to work built from src. Reppard n I said f it n just added the prebuilt mms fix.
New build up, details in OP.
Sorry, I did not include sammyz/MMS fix(hack)...I don't work that way.
It would be great if someone could get me a logcat with trying to send and receive an MMS without the fix and also with the fix.
jaysonr35gtr, the new kernel I'm working on will be for ICS
Thanks,
Bob
Does this build fix Caller ID?
Just Tried the new build. Caller ID is still a no go, that is my biggest pet peeve. Funny thing is the SammyZ patch of your rom has it working half the time. Reppards rom works 100% with callerID and the Sammyz ICS themed 2.3.7 ROM has Caller ID working as well.
Blah I hate it cause BobZ is the most useable and smooth rom, but I still need to run Reppards as my daily runner.
Try this....
CM7.2.0RC0-MS690-BobZhome-031712.zip
Sorry this is kinda late Thank you it worked perfectly
Well, I tried the new build tonight. I got it all up and running, even MMS (I did have to flash the MMS fix). I used this guide to restore all my apps: http://androidforums.com/optimus-m-...-your-data-may-also-work-coming-froyo-gb.html and was quite happy with it. Then I tried to activate wi-fi. No go. I kept getting "error" (I was in settings> Wireless & network settings) when I would attempt to put the check in the box for Wi-Fi.
I restored my nand back up.
