PlayfulGod
Extreme Android User
camera app cant connect to camera either on mine. Tho I think there were some camera issues listed in the wiki.
I'd guess he got busy, he'll prolly get it up tomorrowSo no build tonight?
I figured out why it does it, its the version of the cyanbreadx theme off the market. It doesnt do with the system theme.anymore issue with your notification going transparent, i havnt exp that yet....
Just read over the instructions real good and you should be fine. U just need to have root (Z4Root is the easiest/best way IMO) and install clockworkmod's rom manager. And if it does freeze someone here should be able to help you get past it. But with all the flashing I've done in the past weeks I only had one bad flash n it was with cm6 loli really want to try this but im afraid of my phone messing up or freezing on the huawei screen like some had said
re-install google voice search, that fixed it for me.After having problems with Better Keyboard 8, I un- and then reinstalled it. Working better now but where did the microphone go for the talk-to-talk feature? Better Keyboard 8 has it, correct?
Anyway to change font colors on the phone itself?
NP I figured that out when voice search wouldnt work n it sent me to the market lolThanks. I was hoping that I could get to work from the SD card but ended up getting force closes. Works great from internal phone storage though.
Anyone else having trouble receiving calls? 1 Ring then to voice mail, or no calls at all? Just missed calls?
I'm was with Cricket and it was a nightmare. No one could really answer what the problem was so I gave up and signed a contract with Sprint last night.
Has everyone tried the new version of CM7?
IMO, this is quite stable compared to the last version. I am getting a lot less force closes, was able to install Swype, and everything is just working dandy.
I know mms and camcorder are still an issue, but I've never had this phone have 90mb of free RAM...until this update.
GJ Isaac, thank you kindly for all your hard work.
the current is recommended but I thinks its been said 2.5 will work.Do you have to use cwm 3 or could you just use 2.5.1.8?
Your right the latest build is just fantastic. I don't regret installing it at all!
WiFi seems to be working fine for me, tho I dont tether it to anything lolThe one thing that I have problems with is the Wi-fi. I know that Isaac tried to fix some of the problems with the most recent build, but it still seems a bit finicky to me.
MMS is unimportant to me, but Wi-Fi is definitely a huge priority for me.
I hope he works a lil on this in the next update.
My input.
