nuttmeg
Extreme Android User
If my phone and mms is working, do I need the metroOFF fix?
no...if all is working, but make a backup of your current rom in cwm...
I flashed the new build 05042011 of CM7 last night and now I'm not receiving calls. I wiped data and cache partition, formatted boot, system, dalvik cache, cache, and data before flashing the new build in CWM 3.0.0.5. Is anyone else having this problem? Please help!
your carrier might be having some issues, and metro is known for that...
Anyone else seeing a marked increase in power drain with CM7? Running all my normal apps, and the CM governor is set to Ondemand at 710, but seeing about double the power drain. Installed Autokiller to see if that helps, but wonder if anyone else has seen this, or if it's just me.
Yep I have noticed it....I unplugged my phone at 7am this morning and right now I have 26% that I am going to try and make last until at least midnight,its 5:25. Granted I made 2 short augmentative phone calls and sent maybe 20 texts since this morning and took one or two pictures...But thats not alot of use, I think anyway.
I just fixed the Camcorder. CM7 on the Ascend is now pretty much fully functional.
I have noticed this as well but I took SetCPU off and a couple other system monitors that I had goin and saw a huge increase in not only battery life but also general speed of the phone. I think this is just because we are running an Android OS that wasn't even supposed to be on this phone and really is made for the newer, higher ended devices. A little sacrifice and work around should help. Also, I have CM6 on my "dev" phone which has service until the end of the month and I have found that the battery lasts twice as long than the phone with CM7, both being Huawei m860's.
The fix will be in the next build. Check back on my twitter for the heads up.
thanks for all your hard work issac If I could I would gladly donate to your cause...But I think the roaches in my apartment have more ka-ching than me at times lol. Jk I do not have roaches, but am broke.New build 05052011 is up. Camcorder is fixed. Enjoy.
search "drivers for cricket huawei ascend" from the search bar at the top of the screen.I have a question where can i get the drives for the ascend for cricket i have a pc laptop with windows 7 on it
Question?n Am I able to just flash over the current rom without doing any wipes? I just finally set up phone and dont want to lose everything. Also I have 2 pic messages I am trying to figure out howto dl so I dont want to lose those. I flashed metro off last night but it did not fix anything. Not sure if there are settings I need to change? Any and all help is much appreciated.
