the only apn there was when i opened the listings was cricket, i had to enter the apn settings for metro mms
Upvote
0
I have just flashed the latest build and has connected to CricKet automatically.
you should have to mess with those settings..
yeah for cricket it works just like out of box...but for metro on my end on one of my phones, i had to flash the metro off-roaming off...but all is good!!!
Yes. You have to use the MetrOFF to get MMS going. ^.^you had to do this for mms to work right?
So I am guessing just entering the apn info wont cut it in this build lol damn it.
Sounds like this is a flash back to stock and start over moment. And no, most likely you did not brick your phone. BTW, if you use the 0502 version of CM7, you should not have SD issues.
http://androidforums.com/huawei-ascend/282038-how-flash-huawei-ascend-stock.html
I know its always recomended but is it absolutly necessary to clean wipe before installing this update or could we just install this over CM7-05022011? Just wondering as I have my phone just the way I would like it and would like to retain the settings and all around setup of the phone. I tried using titanium backup after a clean wipe from cm7-04162011 to cm7-05022011 and it caused my phone to always remain stuck at the CM7 bootanimation.
I think you just answered your own question. But most launchers have a setting to back up settings and icon placement to your sd card. After you flash just go to the launchers settings and import the old settings. If i wasn't clear, always wipe.
I agree it is a bit of a hassle but I'm not gonna frown on updates. But the main reason why the wiping is advised is because when problems arise it is usually due to the person not wiping. Also some people don't do so well with trouble shooting the problem so it's just easier to wipe. But if you know a lot about flashing and trouble shooting, it could not hurt to try without the wipe.
Well, the only reason I was asking was because USUALLY when Isaacj releases a new version he notes that a clean wipe is more than likely required to flash that version. Since I hadn't noted anything on any of his posts or prepaidandroid.org, I figured I'd ask to save myself some time and effort and possibly clear up any questions anyone else may have had.
Also, it would be nice to just update like you would with a stock android OS rather than having to clean wipe everytime. I know that this is not the best thing since a lot of apps will start to force close as such but atleast you could uninstall those apps and reinstall rather than having to go through the hassle of backing everything up and reinstalling everything each and everytime as there have been 3 updates to this rom in the past 4 days. And, like any tech head, I generally like to keep my rom up-to-date.
How can I download the latest CWM, CM7, Gapps? Used this guide originally but want to know how to get the latest in future. Thanks.
Thanks for giving me a reason to actually use Twitter.Bookmark this page: CM7-Ascend - Prepaid Android
I'm also going to setup a twitter account and I'll tweet when I have new changes.
