Hello,
I would like to flash CM7-Ascend-05022011, but I see Isaac has put up a new version of ClockWorkMod, 3.0.2.8. I however, still have the version from build 04162011, the build before this one. Do I have to install the latest version of ClockWorkMod?
If I do will it be like installed ClockWorkMod 2.5 (Green & Black) with the different versions of file to run depending on your operating system?
I see on the CM7 WiKi, under the Notes Section, the note of Angry Birds not installing on the SD is fixed? Does this also apply to several other games and apps that do not work on the SD Card?
Also I see it now says " Format the card in CWM. I usually do 256-ext and 32-swap" Does this mean that in ClockWorkMod there will be an option to wipe the SD Card? Do I do this before I put the Rom and Gapps on it?
Thanks,
Lenny
